NI Labs Discussions
取消
顯示結果
搜尋替代
您的意思是:
CPX Festo Ethernet/IP - Labview
I'm trying to set up connection between PC and Festo CPX-FB36 (with Ethernet/IP)
I linked the module via MODBUS TCP , and it worked correctly all the outputs and valves were activated.
For Ethernet /IP it is configured as follows .
 CPX-FMT configuration
with this the communication is established, now all that is missing is the sending of data, to activate outputs and valves.
does anybody have any suggestions?
0 積分
1 條訊息(共 11 條)
10,696 檢視
hello ,
are you find a solution ?
because i have the same situation and  i dont know how can i use CPX Festo with LV,
thanks
0 積分
2 條訊息(共 11 條)
10,185 檢視
Yes i finding to solution with modbus tcp and ethernet /ip
3 條訊息(共 11 條)
10,167 檢視
please can you give me a project or tutorial how can i use it because i'm beginner in labview and i dont know how to use it , thanks
0 積分
4 條訊息(共 11 條)
10,146 檢視
is it possible to send this VI to me? would appreciate it.
0 積分
5 條訊息(共 11 條)
8,829 檢視
good day
I can send you the VI file, I have also done it with SMC interfaces, it is quite easy, and also with Ethernet/IP SMC, FESTO, Mitsubishi controllers, etc, they have to be with Ethernet/ip protocol.
best regards
0 積分
6 條訊息(共 11 條)
8,815 檢視
can you post it here or do you prefer my email?
0 積分
7 條訊息(共 11 條)
8,803 檢視
Can you post your solution (or VI) here? I have a similar issue so it might help me, and others in the future, too.
Thank you!
0 積分
8 條訊息(共 11 條)
8,097 檢視
hello, the only problem I had when developing the project is the attribute and the class, this is focused on ethernet/ip CIP so it was not in the manual.
best regards
you can send me an email
imartinez@integracionid4.com
0 積分
9 條訊息(共 11 條)
8,006 檢視
Can you please send also to my address the solution?
perelliraffa@yahoo.it
0 積分
10 條訊息(共 11 條)
7,520 檢視
