NI LabVIEW,CVI,数据采集等产品讨论区
传统daq和daqmx 数据存储问题
cause you select "Scan NSamp" ,it is 2 D certainly. if you need 1D array, select 1sample.
actually, N sample means, LV logs the data at one point with N times. it is precise action ! and I like it.
________________________________________________________
Try to make everything Automatic
Message 11 of 15
(2,430 Views)
actually, N sample means, LV logs the data at one point with N times. it is a precise action ! and I like it.
Message 12 of 15
(2,430 Views)
See attachment, where is 2D ?
Message 13 of 15
(2,429 Views)
thank you
yukee
总感觉2种方法采集的得到的数据组织方式不一样。
Message 14 of 15
(2,420 Views)
明白了,原来1维数组是以行排列,到头了就转行
    我误以为2维数组
Message 15 of 15
(2,418 Views)
