NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
传统daq和daqmx 数据存储问题
cause you select "Scan NSamp" ,it is 2 D certainly. if you need 1D array, select 1sample.
actually, N sample means, LV logs the data at one point with N times. it is precise action ! and I like it.
________________________________________________________
Try to make everything Automatic
0 项奖励
11 条消息(共 15 条)
2,461 次查看
actually, N sample means, LV logs the data at one point with N times. it is a precise action ! and I like it.
0 项奖励
12 条消息(共 15 条)
2,461 次查看
See attachment, where is 2D ?
0 项奖励
13 条消息(共 15 条)
2,460 次查看
thank you
yukee
总感觉2种方法采集的得到的数据组织方式不一样。
0 项奖励
14 条消息(共 15 条)
2,451 次查看
明白了,原来1维数组是以行排列,到头了就转行
    我误以为2维数组
0 项奖励
15 条消息(共 15 条)
2,449 次查看
