NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
x-y chart scale problem
I am using an x-y chart and I allow the user to select auto. scale
and default scale as appropriate using the property node.
Sometimes, when the scale is changed, one of the scale
is overlap, one of the scale is constant. This problem is not
always repeatable but occurs at window vista regularly and I
have recently discovered it in a LV built exe also (when the exe
is restarted it's OK). I am using LV8.5.
Has anyone got a fix for this?
0 積分
1 條訊息(共 2 條)
4,613 檢視
Hello htma,
    Is it possible you can upload a simple example code for this problem?
    It would be better if we can have the source code at hand to solve this problem.
    Thanks for your kindly help.
    Best Regards,
    Alexander Chen, National Instrument Taiwan Application Department
0 積分
2 條訊息(共 2 條)
4,580 檢視
