 Experts
			Experts
			01-23-2013 08:59 AM
where can I get CD4047 or its match in Multisim 12?
I am designing an INVERTER circuit in MULTISIM COMPONENT EVALUATOR 12.0 software.
but on doing so I can't find the IC (Integrated circuit) CD4047. I have tried to search CD4047 match component (can replace it) on the internet but not found?
1. What can I do or how can I replace its Match component?
2. In future when I design in Multisim, when I coudn't get components in the data base of MULTISIM, what solutions can you give me?
Hoping to get from your Answers
Thank you!
01-23-2013 09:39 AM
Experts,
There is the CD4538 which I believe is a similar chip (its dual - so you get 2).
1. If you locate the CD4047 model online, or you can use 1/2 of the CD4538, you can use the Component Wizard to import a custom component into Multisim.
2. There are various techniques to get models/parts into Multisim. If you can find an equivalent model you can use you can create a part using the Component Wizard. There are various SPICE modeling marco modeling techniques for creating models, but the complexity depends on the type of part and how much detail you need from the model. The best method is to locate the SPICE model from the manufacturer and follow our Component Wizard steps to import the new model into a Multisim part (usually with the most challenging step being the symbol - spice model mapping).
- Pat N
01-23-2013 09:42 AM
 sameeeer
			sameeeer
			04-20-2013 01:15 AM
