Multisim and Ultiboard
using nest if then statements in ABM component
I have a two input, 1 ouput circuit as in the schematic attached. My third node is defined at the bottom by the very high resistance voltmeter. What I have is a user-defined ABM current source that is dependent upon other parameters within the circuit. What I am wondering is this, is my conditional statement entered in the correct format? The conditions are particularly complex and outline as follows:
If the voltage difference between V2 and U1 is greater than 0, then the current in the ABM = 10^-12
If this voltage difference above is not greater than zero and if (V(1)-U(1))<(V(2)-U(1)), then the ABM current is (0.1*((-(V(2)-U(1)))^0.35))*0.00001596*(((V(2)-U(1))-(V(1)-U(1)))/2)*(V(1)-U(1))
Otherwise, if (V(1)-U(1))>= (V(2)-U(1)) then, the current is (0.1*((-(V(2)-U(1)))^0.35))*0.00001596*(((V(2)-U(1))^2)/2)
As you can see, these are very complex conditions and my concern is that I cannot simply type in U1 and get the compiler to understand that I want the voltage being read at the bottom-node voltmeter. I believe that I am using the correct nesting as far as the coding format is concerned: if(T,X,(if(Q,R,S))).
Any help would be much appreciated, and clarification can be provided.
(5,861 Views)
Accepted by jade.swordy
I am not sure why its not throwing an error for the use of U(1), perhaps that's a valid reserved word.
If you want to reference a voltage correctly it should be V(net_name) for single ended voltages (referenced to ground) or V(net1,net2) for differential voltages... For ABM models I suggest turning on net visibility for the entire schematic so you know the net name at the positive terminal of U1 or any other location for that matter.
I think the syntax you have for if/then/else is correct otherwise.
Pat Noonan
(5,851 Views)
And am I correct in that by differential voltage your mean that V(1,2) would be the voltage difference between node 1 and node 2 (1-2)? Just to check.
(5,829 Views)
jade.swordy,
Yes for the ABM a differential voltage is V(1,2) , meaning:
V(1,2) = Voltage at net "1" - Voltage at net "2",
Example: Probe1 = +5V, Probe2 = -5V...
Pat Noonan
(5,823 Views)
