 Mathan
			Mathan
			08-28-2008 04:14 AM
NDS352AN and NDS352AP were used for switching as shown in the circuit. It works well for a bus-powered device. But for self-powered devices, it doesn't switch ON/OFF the device.
For ON condition, 5v is the output and for OFF condition also it gives 4.5v , thus the device is always ON.
Any suggestions?
Mathan
 kittmaster
			kittmaster
			08-28-2008 04:04 PM
 lacy
			lacy
			08-28-2008 08:07 PM
I agree with Chris, but there is more here. He is using Depletion Mode MOSFETs and these things conduct without a voltage present on the gate and require a reverse bias on the gate to turn them off. Since he is using a digital signal that will never occur. Therefore they will never give what he is looking for. I would suggest using Enhancement Mode MOSFETS as these act more like a normally open switch and probably would be better suited to this application.
I hope this helps.
 kittmaster
			kittmaster
			08-28-2008 09:40 PM - edited 08-28-2008 09:43 PM
08-29-2008 05:13 AM
 kittmaster
			kittmaster
			08-29-2008 07:14 AM
Only you can answer that, you need to know how much current will pass through it, how much power loss there will be based on Rds_on. If your doing just simulation, anything will be "ok", but only you know what your app is and should research what your needs are......I like to run my max at 50% of the device capability........because I can......but typically avoid anything over 85% of the max values..........good luck
