08-05-2009 12:11 PM
I needed a part for an MMBT2222A, so I copied the 2N2222A from the master database to the user database, and changed the footprint to IPC7351/TO-236AB.
That seems fine, but whenever I place one or renumber components, I get the RefDes prefix of U instead of Q which I expect?
What do I need to do to get the component refdes prefix to be Q like all the other xistors?
Dave
Solved! Go to Solution.
08-05-2009 01:15 PM - edited 08-05-2009 01:24 PM
Hi Dave,
I am assuming you are referring to Multisim. To change the RefDes of a component in Multisim, you need to change it at the instance level:
In Ultiboard you can change the RefDes at the instance level or at the component level:
(Instance Level)
(Component Level)
Let us know if this solves the problem.
08-05-2009 03:14 PM
Hi Dave,
The other possibility is that Multisim uses a default RefDes prefix for new components. This default is set per family, so depending on where you saved the component in your user database, you may get a different default RefDes prefix.
You can change the default for any family:
1. Go to Tools > Database > Database Manager
2. Select the Family tab
3. In the Family Tree, find and select the family where you saved the component.
4. Change the Default Prefix to Q.
5. Click Close
Now when you place the component, the RefDes should start with Q.
08-05-2009 04:08 PM
Garret,
YES, that was it - thank you very much.
Dave
