Multisim and Ultiboard
multisim
I'm just starting to learn to use multisim. My first project is a simple 555 astable oscillator. It should oscillate at about
1800Hz. I'm getting nothing out of the simulation. I can't see what I'm doing wrong. Attached is a screen shot of my setup.
Whould appreciate any insights. I've also set the initial conditions to zero, no change.
Penguin11
Message 1 of 10
(7,458 Views)
You should ask a moderator to move this to the Multiism Board.
Lynn
Message 2 of 10
(7,450 Views)
thanks.
Message 3 of 10
(7,431 Views)
Hi Penguin,
I think you meant to make C4 0.1uF and not 0.1F.
If you can't get the circuit to work, it's better if you post the Multisim file so that I can see how you built the circuit. There are things in the Multisim file that I can't see from a screen shot.
Tien P.
Message 4 of 10
(7,380 Views)
Thaks,
Tien,
I mean't to make it .1uF, as you pointed out. I'll try that, but I've used various sized caps with no results. I'll send the file if this fails.
Message 5 of 10
(7,352 Views)
I'm also a new user so some one please help me to developing energy meter
Message 6 of 10
(7,336 Views)
I tried the .1uf no change. Attached is the timer file.
Message 7 of 10
(7,320 Views)
Two things:
1. Move R5 around, you will see there is a wiring problem.
2. I suggest you use the 555 from the "Mixed" group under the "Timer "family. The rated 555 you selected have extra codes in the model to determine when it should blow up, sometime the extra code can make the model less accurate. It does simulate but you don't get the 1.8kHz
Tien P.
Message 8 of 10
(7,315 Views)
Accepted by penguin11
Thanks Tien,
I'll try those two things.
Phil
Message 9 of 10
(7,293 Views)
That worked. The lesson for me is to verify each connection, and stick with the mixed use components.
Phil
Message 10 of 10
(7,229 Views)
