 ronquan
			ronquan
			11-24-2010 01:17 PM
How do I use the magnetic core (either virtual or not virtual) to model a transformer, and circuit that uses the transformer. How do I use the non-linear transformer? What do the pins of the magnetic core connect to. Are there any examples? If not can someone provide an example?
ronquan
11-25-2010 08:42 AM
The magnetic core can be a little cumbersome to use.I will suggest another component if I can understand your requirements.
What effects are you trying to model (e.g is there coil/magnetising inductance and is this inductance linear? leakage inductance)?
Also, what is the configuration (#of primaries, #of secondaries)?
