Multisim and Ultiboard
取消
顯示結果
搜尋替代
您的意思是:
is there a way to find the total resistance of a circuit?
i have just started using multisim pro. 10.1 is there a way to use the program to find the total resistance of circuit, with parallel and series connections?
1 條訊息(共 8 條)
32,617 檢視
Hi there,
Thank you for using Multisim! There is a multimeter instrument in Multisim. It is the first instrument in the Instruments toolbar. The multimeter has a ohmeter function. The multimeter works by inserting a very small test current through the circuit and measuring the voltage drop across its terminals. This is realistic as it works the same way as most real multimeters, but keep in mind that this also means that you may have trouble measuring resistances of nonlinear circuits and small signal resistance.
The instruments toolbar is on the right hand side of Multisim in its default layout. You can always reenable the toolbar by clicking View>>Toolbars>>Instruments.
Hope that helps. Let us know if you have any more questions.
Yi
Software Developer
National Instruments - Electronics Workbench Group
0 積分
2 條訊息(共 8 條)
32,607 檢視
okay but how do i make it work?
0 積分
3 條訊息(共 8 條)
32,564 檢視
Take a look at the attached image. One thing that might be unintuitive is that you must have a ground connected in your circuit somewhere. Otherwise, you would connect up the circuit just as you would in real life.
Hope that helps.
Yi
Software Developer
0 積分
4 條訊息(共 8 條)
32,561 檢視
okay thank you very much! that was a big help!
0 積分
5 條訊息(共 8 條)
32,530 檢視
Ah but that resistance measurement is only a basic measurement, right?  In other words, as in reality, resistance measurements cannot be made with the power on, due to the combination of the meter's current source and the circuit's current flow...
....unless you're dealing with a FET.
That's what's cool about FETs (at least I think.)  You can set up a gate to source voltage but then connect an ohmmeter from drain to source and measure the channel resistance WITH THE POWER ON.
See the attached.
0 積分
6 條訊息(共 8 條)
32,513 檢視
Pleae tell me faster how to calculate equivalent resistance in multisim.
Or
How to insert Req component in multisim.
0 積分
7 條訊息(共 8 條)
19,713 檢視
Hi User5678! Welcome to the forums!
The original post here is more than 10 years old--you'll usually get more traction on the forums if you go ahead and make a new thread when threads are this old.
That said, I've linked a video tutorial here that might help answer your question. If you have more questions, I'd recommend making a new thread so more people will see it.
Claire M.
Technical Support
Certified LabVIEW Developer
0 積分
8 條訊息(共 8 條)
19,697 檢視
