10-23-2012 04:10 PM
how you guys doing ?
I hope you can help me with this , I am not sure i am on the right board for such a question.
the attached picture shows the internal circuit of an operational amplifier LM324. it is used to measure the difference of voltage between 2 input voltages.
I just wanna know how does it do that ?
any help ?
10-23-2012 07:31 PM
Bill David,
That is a fairly standard differential amplifier circuit. You can look at nearly any basic electronics text to find a description of that or a similar circuit.
Fundamentally, the current through R1 is approximately constant. That current is split between the two transistors in proportion to their base voltages. If the voltage at input 1 is more positive than the voltage at input 2, then the current in Q1 increases and the current in Q2 decreases. A decrease in Q2 collector current produces a smaller voltage drop across the collecter resistor Rc(2) and the output voltage rises toward Vcc.
Lynn
