Multisim and Ultiboard
how to solve simulation error
Hi, I am new out here,so need your help with a few things.
I am continuously getting a simulation error with almost every circuit i am implementing. It runs the convergence assistant but it couldn't reproduce the error for any of my circuits so didn't help.
Is there any tutorial available or any website which helps out on how to design to remove such errors or steps to rectify them ?
regards,
S!D
(4,968 Views)
Hi S!D;
Since you don't give much information on the error you're obtaining I can think of two common issues, the first one is that Multisim is searching for an unexisting folder and the second one is an issue regarding the power inputs of your circuits. I attach two links to documents that can help you solve either one of the issues I mentioned, but if you get a different error from the ones I've told you, could you send more information regarding the error you obtain?
http://digital.ni.com/public.nsf/allkb/221393F998C08491862571ED0077FCC3?OpenDocument
http://digital.ni.com/public.nsf/allkb/15526EB2464F3EDD8625722C00696BB0?OpenDocument
Hope the information is useful.
Good luck
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
(4,949 Views)
I'm having the same problem, when I connect VCC sources to my circuit it says no sources detected. Just tried creating a simple OR gate. This is my circuit.
(4,823 Views)
The same circuit when I construct at the school computer it works just fine.I can't paste it I use open office.Any circuit even if I put a ground it still says the same thing. I have the 10.1 evaluation version.
(4,822 Views)
