Multisim and Ultiboard
hole in rounded rectangle not properly showing in preview and printing
i started using ultiboard. what i notice is that a holed rounded rectangle not properly showing during preview and printing. kindly check the attached file. anybody can help?
(3,277 Views)
Hi zackde,
I am looking at it, it seems to be a bug but I have to run some tests to confirm this.
By the time, what version and edition of Ultiboard are you using? And what OS?
José F.
(3,232 Views)
hello José F.,
thanks for your reply. i'm using ultiboard 13 in windows 10 x64. 'hope it could resolve or have a work around soon.
thankz,
zackde
(3,181 Views)
Thanks for the information!
I will consult with my colleagues at R&D and will post an update as soon as I get more information.
José F.
(3,165 Views)
Accepted by topic author zackde
Hi Zackde,
This is an unexpected behavior and was reported to R&D as a bug in CAR # 693366. You can check in further software/patch releases if the issue was fixed using the CAR number.
You can have the files printed by exporting the design in Gerber format, and use a tool to print it or use a Gerber to PDF converter tool and print the PDF.
José F.
(3,157 Views)
hello José F.,
again i very much appreciate your immediate reply. your information already noted likewise i already tried your suggestion.
i'll check every now and then for its fix.
thankz,
zackde
(3,149 Views)
