Multisim and Ultiboard
graphing at fixed frequency with arbitrary x-axis
I'm trying to use Multisim to model an effect in a capacitance bridge. I have two voltage sources, and I want to sweep one of them while keeping the other one fixed. This is an AC measurement, but I'm fine keeping it a fixed frequency (or only measuring a few frequencies). I'm able to do a parameter sweep of the voltage source and measure the output voltage at the other end of the bridge, but Multisim produces graphs that where the x-axis is frequency/phase and the steps in voltage are overlaid as separate lines. How can I create an analysis/graph where the stepped voltage is the x-axis, and the frequency is overlaid as separate lines (or kept fixed)?
(3,550 Views)
If you want an graph with everything on it you can simply pick a graph and ovrlay the traces unto another graph. Then in the properties you can select the scales etc.
Miguel V
(2,873 Views)
