02-27-2008 01:25 PM
02-27-2008 05:34 PM
02-28-2008 06:57 AM
02-29-2008 10:50 AM
02-29-2008 08:00 PM - edited 02-29-2008 08:01 PM
I am sorry no one has replied to your inquiry. It is not an easy thing to couple inductors in Multsim without creating a new part (at least I haven't found an easy way to do it). This part would be a Multi-winding transformer and can be done with the models makers in Version 10. If you are using an older version then I would not know how to do this.
What I can do is to try and create a part for you and post it to the forum for you to try. This may take a little time to do but I will give it a try.
03-01-2008 08:11 AM
03-01-2008 10:33 AM
I was unable to use my first idea about the models makers. Without the specifications of that transformer (primary voltages and secondary voltages) I could not do it the way I planned. What I did do was to create a generic transformer with a model I created that will be easy for you to edit to your particular transformer.
I have included instructions on the schematic on how to edit it. You will need to find the information on the transformer you are trying to model in order to edit this one to match it.
I hope this helps some as this is all I could come up with. The only other option is to goto the manuafacturer's website and see if they have a pre-made model for it that you can use to create a more accurate representationl of it.
03-04-2008 08:44 AM
03-04-2008 08:41 PM
Thanks Max, I forgot about the Spice Block (I haven't used it very much, if at all). That was some good information and very cool when I tired it. This would make it easier for the user to couple these coils and still be able to place them anywhere on the schematic instead of having them tied to a stationary transformer type symbol symbol.
Very nice. Thanks very much for your input on this it is greatly appreciated.
03-05-2008 06:22 PM
Iacy, thanks for the inductance !!
but i hawe yet two question :
- where is the L1,L1,L3 in the diagram ?
- in EWB 5 it is possible to create the form from inductance (L1,L2,L3) ?
Adi
