Multisim and Ultiboard
digital clock reset problem with 74193N
Hi, i'm designing a digital clock circuit.
However, i faced problems during reset part.
when i tried to reset on 3(U11) with 1 NAND gate and 2 NOR gates,
i think i don't make mistake to reset with 0011(U3),how come the 3 will also appear on the seven-segment display?
Well,i also wonder how can i reset  the other seven-segment display(U9) to show the following sequences:
0,1,2,3,4,5,6,7,8,9,0,1,2,3,0,1,2,3,4,5,6,7,8,9,0,1,2,3,0..
Lastly, is that possible to configure the transmition speed in multisim 11.0?
Thanks..
(5,172 Views)
There were a few problems with the circuit which is why the clock was not reseting at 3. I have modified the file. Please take a look and see. You will need to add a buffer between the second input and the AND gate because otherwise, the gate will trigger before the output has actually reached the desired state.
I had to edit the delay time in the buffer to make it work of this circuit. To edit the delay time, double-click the Buffer and under the Value tab, click on Edit Model. You can change the rise time and fall time from this window.
Hope this helps.
Tayyab R,
National Instruments.
(5,140 Views)
