Multisim and Ultiboard
Why do these similar circuits give different graphs?
I was trying to find out the phase shift required to eliminate transient in an RL circuit with sinusoidal input.
I calculated phase shift required is 81 degrees.
I made two circuits for this purpose. 1st circuit eliminates the transient but not the second one. I don't understand why.
Circuit 1
Circuit 1Circuit 1
Graph 1Graph 1
Circuit 2
Circuit 2Circuit 2Graoh 2Graoh 2
(3,578 Views)
-параметры анализа нужно изменить
(3,569 Views)
Accepted by topic author miyawooo
Hi miyawooo and tipa,
The two circuits produced different results because the initial circuit conditions are not the same. The culprit here is the Time Delay Switch but the initial conditions of the two circuits can be made similar to obtain identical output graphs.
Perhaps miyawooo don't very well understand the reply from tipa because it's from Multisim (Desktop) application and the texts from the dialog boxes don't readily translate. Here is a more detailed procedure using Multisim Live:
First we'll run a Transient Simulation and obtain a graph from Circuit 1. Click on an empty space in the schematic diagram of Circuit 1 then click the gear icon near the top-right area of Multisim Live window to open the Configuration pane. Select Transient from Simulation settings and set End time to 10 ms. From the image below it can be seen that Transient Simulation End time is set to 10 ms (10e-3 s) for Circuit 1,
Circuit 1 with Transient Simulation End time set to 10 ms.Circuit 1 with Transient Simulation End time set to 10 ms.
Running the Transient Simulation produces the Grapher output for Circuit 1 below,
Circuit 1 Transient Simulation Grapher output.Circuit 1 Transient Simulation Grapher output.
Note that the graph of PR3 (orange/amber/gold) overlaps the graph of PR2 (cyan).
For Circuit 2, click on L1 to select this component then click the gear icon near the top-right area of Multisim Live window to open the Configuration pane (an alternative is to double click L1). Click on the IC (Initial current) check box and leave the default value of 0 A. The image below shows these,
Circuit 2 with L1 IC (Initial current) enabled with a (default) value of 0 A.Circuit 2 with L1 IC (Initial current) enabled with a (default) value of 0 A.
Next, click on an empty space in the schematic diagram, the Configuration pane shifts from Item to Document. Select Transient from Simulation settings and set End time to 10 ms. To make the initial conditions of Circuit 2 similar to initial conditions of Circuit 1, change the Initial conditions setting from Determine automatically to User definedThe image below shows Circuit 2 with Transient Simulation End time set to 10 ms (10e-3 s) and Initial conditions set to User defined,
Circuit 2 with Transient Simulation End time set to 10 ms and Initial conditions set to User defined.Circuit 2 with Transient Simulation End time set to 10 ms and Initial conditions set to User defined.
Running the Transient Simulation produces the Grapher output for Circuit 2 below,
Circuit 2 Transient Simulation Grapher output.Circuit 2 Transient Simulation Grapher output.
We can conclude, through comparison of the two Transient Simulation graphs, that the simulation results for the two circuits are the same.
Note that for Circuit 1, the output when Initial conditions is set to Determine automatically is the same when L1 IC (Initial current) is enabled with a (default) value of 0 A and Initial conditions set to User defined.
G. Goodwin
(3,534 Views)
Браво! Исчерпывающий, грамотный ответ, как всегда!
Жаль, что я-не твой брат!
 А замечание насчёт диалоговых переводов- учту...
(3,529 Views)
Thank you so much for the answer. I couldn't reply because I entered into a depressive period and disconnected from my study routine. Now I am back on track again. This answer definitely triggered the motivation.
(3,410 Views)
-я рад, что вы выздоровели!
(3,404 Views)
Hi miyawooo,
I greatly appreciate your response. I'm honored to learn that we were able to help not only in assisting you to obtain useful simulation results but also in personal trial that you disclosed to us. Just like tipa I'm also glad that you surmounted the distress and regained strength and determination.
G. Goodwin
(3,395 Views)
