Multisim and Ultiboard
Using multiple databases
Hello Paul,
my colleague tested this with exact the same version that you have. I made some screenshots with the exact steps that I am doing. In case it doesn't work, can you try this with a new design? Just create a new design, place some components and try to change these attributes.
Are you using the full or the power pro edition?
Martijn S
Applications Engineer
NI Netherlands
Message 11 of 14
(1,741 Views)
It is working with a new ultiboard file and place directly the components in ultiboard.
But when you use multisim and transfer --> transfer to ultiboard 10 (or Forward Annotate to Ultiboard 10) your methode won't work anymore.
Message 12 of 14
(1,739 Views)
Hello Paul,
we did some further testing with examples from Multisim; when transferring those examples to Ultiboard we see the same problem in 10.0, when doing this (with the same examples) in 10.1 we are able to make the values visible.
This is an issue which is related to your version and has been resolved in the latest version. Unfortunately there is no work around.
Martijn S
NI Netherlands
Message 13 of 14
(1,694 Views)
Thank you for comfirming the error.
Message 14 of 14
(1,689 Views)
