Multisim and Ultiboard
Unable to open LV instrument
Accepted by Getwonder
Remove the instrument from the lvinstruments folder and place the original file that you downloaded. It seems that this VI needs the LaVIEW Run-Time Engine (RTE) version 8.2.1.
Note that this version of the RTE is compatible with Windows XP (32-bit), 2000 (32-bit) and Vista (32-bit and 64-bit).
Please let me know how it works.
Fernando D.
Message 11 of 18
(4,724 Views)
Thanks alot.
It's working after installing the LV RTE 8.2 and the previous LV Instrument.
Here i want to give a suggestion that pls mention the version of LV RTE on the website so that one dont go into such problem
Thanks very much for your help.
Message 12 of 18
(4,712 Views)
I am glad to hear that the issue has been resolved.
Thanks for the feedback, I will make sure this document gets updated.
Have a nice day,
Fernando D.
Message 13 of 18
(4,698 Views)
sir,
even after copying the ecg electrode.llb file i cant see the ecg signal in labview instrument .I have multisim 12.0 version plss gimme sum solution
Message 14 of 18
(4,374 Views)
You have to make sure you are copying it to the right directory. The default directary for LabVIEW can be found under Options » Global preferences.
Miguel V
Message 15 of 18
(4,342 Views)
Hi friends,
  Anyone help please .....
   How to give ECG signal as an input in multisim???
Then I tried to simulate ECG signal amplifier which is in your website, i have multisim 12.0 version, labview 2010 and labview 821 runtime engine but on clicking XLV1 i m getting like this
((Unable to show the LabVIEW instrument. The LabVIEW instrument library "LVInstrIF821/ECG_Electrode" cannot be found or loaded.
Ensure the VI library file exists in the LabVIEW instruments path "E:\Program Files\National Instruments\Circuit Design Suite 12.0\LVInstruments\".))
 what can i do to get ECG in this circuit
Message 16 of 18
(4,187 Views)
Can you please give me the link to download the ECG electrode LabView Instrument
Message 17 of 18
(2,713 Views)
hi, did you knew how to download it? because I need it too
Message 18 of 18
(1,280 Views)
