Multisim and Ultiboard
Transient time point calculation did not converge error
Hello
I am unable to get output simulation sue to convergence error. When the step voltage source changes its value from high to low I get a convergence error which remains unsolved by convergence assistant. I have attached the circuit and multisim file. project.PNG
(3,174 Views)
You may follow the document below to troubleshoot your code at first step.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RqVSAU&l=zh-CN
Since every circuit ends up being a different whole model, simulations settings need to be adjusted in order to get the software to converge. If the specific vlues suggested in the document do not work, I recommend you to play around with the values a bit. I hope this helps!
Technical Support Engineer | 技术支持工程师
National Instruments | 美国国家仪器
(3,055 Views)
