08-07-2019 11:00 PM
Hello
I am unable to get output simulation sue to convergence error. When the step voltage source changes its value from high to low I get a convergence error which remains unsolved by convergence assistant. I have attached the circuit and multisim file.
09-25-2019 08:14 AM
You may follow the document below to troubleshoot your code at first step.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RqVSAU&l=zh-CN
Since every circuit ends up being a different whole model, simulations settings need to be adjusted in order to get the software to converge. If the specific vlues suggested in the document do not work, I recommend you to play around with the values a bit. I hope this helps!
