06-22-2023 10:20 AM
Is there a way to configure an INDUCTION_MACHINE_WOUND or INDUCTION_MACHINE_SQURREL_CAGE to simulate an electromechanical 3 phase generator? I am seeking to simulate an actual low wattage generator in Multisim.
Thank you.
06-24-2023 12:08 AM - edited 06-24-2023 12:54 AM
Вот такой подойдёт? Привет, коллега!
Симулировать надо минут 10-15..., пока синусоида не загенерируется.
06-26-2023 09:30 AM
Покопался в своих архивах, нашёл ещё две модели генераторов, файлы в формате "ms" не сохранились, к сожалению, но их можно восстановить...
06-26-2023 10:26 AM
Hello tipa,
First, thank you for your submissions. My apologies for not speaking or writing in Russian. I am currently working with your Элмехген file. I am going to analyze the output signals with a spectrum analyzer to see if there are harmonics of the outputs. If possible, I would like to add a filter to the outputs to "clean up" the output waveforms.
Best Regards,
rhcj
06-26-2023 10:38 AM - edited 06-26-2023 10:52 AM
Вот ещё генератор с роторной обмоткой. Вместо R4,R5,R6 нужно поставить нелинейные резисторы, или другие компоненты снижающие ток в роторной обмотке возбуждения, дабы ограничить рост мощности и стабилизировать её.
06-26-2023 02:03 PM
Hello again tipa, It is interesting that you can get 3 phases out of this machine, but I am looking to duplicate as closely as possible an actual 3 phase synchronous generator. This machine has a DC input for the rotor and has access to the three phase windings. At approximately 3000RPM, it will output a three phase voltage that is about 120V on each phase. I know that I can use three AC_Power sources, but I was hoping that one of the electro mechanical devices would generate a voltage.
With kind regards,
rhcj
06-26-2023 02:14 PM
I read your message via a translator. I now understand the need for nonlinear resistors to reduce the field winding to control and stabilize the operation.
06-26-2023 03:14 PM
-так я вам показал расчёт генераторов на 30 кВт с фазным напряжением 220 Вольт. Генераторы собраны на синхронных машинах с магнитами, модели с обмоткой возбуждения на якоре, к сожалению, Мультисим не предоставляет. Думаю, сделать такую модель можно на основе асинхронной машины, только добавить вместо"беличьего колеса" обмотку с двумя выводами...
06-27-2023 06:21 AM
Здоровья, коллега! Я давно уже не вижу никаких языковых препятствий при общении в интернете. У меня стоит браузер "Яндекс", который на все языки мира всё переводит автоматически, и довольно точно, особенно технические тексты. Я раньше много соприкасался с дизельгенераторными установками, которые используются в армии. От 2 кВт-бензиновых, до 500 МВт (на судовых крейцкопферных, низкооборотистых дизелях). Если Вы знакомы с другими программами-симуляторами, то можно поискать в них прототип модели синхронного генератора с якорной обмоткой возбуждения, потом рассчитать параметры под ваши требования, а именно 3Х120 Вольт, 60 Герц. Можно в модель THREE_PHASE_WYE ввести зависимый источник, который будет добавлять амплитуду в каждую фазу, в зависимости от поступающего в него постоянного напряжения
06-27-2023 09:19 AM
Hello again,
Thank you for providing some information on your background. I am an instructor at East Tennessee State University. My motivation is to give the students some experience with the electro-mechanical features of Multisim and how they relate to the actual equipment we have in our lab. I agree with you that simulation of three phase generators as a Multisim "Machine" is not going to work well, but I did have some success with other devices, such as a DC machines. Attached are some experiments I ran with DC machines.
With kind regards,
rhcj
