Multisim and Ultiboard
Superimposing two voltage signals
Hi all,
I am trying to simulate the effect of superimposing two AC signals onto one another. That is the high frequency signal (let's say 100 KHz 7 Vrms) onto the 120 Vrms 60 Hz one. In essence this is a power line communicaiton technique. Could I simulate this with two sources set at two different frequencies in series?
Thanks.
Viktar
(5,146 Views)
Hi Viktar,
You should be able to place two AC sources in series, but in parallel you may get a warning message and to get around that just add a small resistor between the sources.
Tien P.
(5,106 Views)
you can use XM10E or XM0U module.
(4,906 Views)
COuld I use XM10E it for FPGA Implementation ??
(4,637 Views)
