Multisim and Ultiboard
Spice model for dac0800
    We are doing a project based on Biomedical for that I want  Spice model of DAC 0800. So that we can test our circuit in multisim.
(5,300 Views)
Unfortunately we currently don't have that model in our master database. You can try to find the SPICE model on the Internet which I did but couldn't get any useful information. You can also try to contact the manufacturer for the SPICE model or use another similar model that has SPICE model in our database e.g. DAC8541. If you have the SPICE code you can manage to create your own component by following the procedure like the one in the example: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH5fCAG&l=en-US
Hope this helps,
Derek Z.
(5,288 Views)
Hello Sir,
              DAC 0800 is of 8 bit where as DAC 8541 is of 16 bit and in NI MULTISIM database only general DAC is available for 8 bit.I also searched in internet but not able to get SPICE model for any 8 bit DAC. If you have SPICE model for any 8 bit DAC it would be helpful.
    THANKS.
(5,266 Views)
