Multisim and Ultiboard
SPICE MODEL IR2153
Несколько форумчан запрашивали эту модель, но, к моему, и не только моему, сожалению, ребята из NI пренебрежительно обходят все обращения, гордо воссиживая на вершине Олимпа, который скоро развалится из-за алчности до бабла...
* Simulation model of IR2153 Level 1 for SIMetrix version 8.3g or higher
* Version: 01.00 (Revision: 316)
* (C) Copyright 2020 Infineon Technologies. All rights reserved.
* Model performance :
* - Static Electrical Characteristics and Dynamic Electrical Characteristics
* are modeled with the typical values from the datasheet.
* - Temperature effects are not modeled
* The following features have been modeled :
* - Switching Characteristics such as propagation delay, peak currents
* - Undervoltage lockout
* PINS:
* | NAME | DESCRIPTION
* | LO | Low side gate drive output
* | HO | High side gate drive output
* | COM | Low side return
* | RT | Oscillator timing resistor input
* | CT | Oscillator timing capacitor input
* | VCC | Low-side and logic supply voltage
* | VB | High side floating supply
* | VS | High side floating supply return
* DISCLAIMER
* INFINEON’S MODEL TERMS OF USE
* BY DOWNLOADING AND/OR USING THIS INFINEON MODEL (“MODEL”), THE USER
* (INCLUDING YOU) AGREES TO BE BOUND BY THE TERMS OF USE HERE STATED. IF USER
* DOES NOT AGREE TO ALL TERMS OF USE HERE STATED, USER SHALL NOT DOWNLOAD,
* USE OR COPY THE MODEL BUT IMMEDIATELY DELETE IT (TO THE EXTENT THAT IT
* WAS DOWNLOADED ALREADY).
* 1. SCOPE OF USE
* 1.1 Any use of this Model provided by Infineon Technologies AG is subject
* to these Terms of Use.
* 1.2 This Model, provided by Infineon, does not fully represent all of the
* specifications and operating characteristics of the product to which
* this Model relates.
* 1.3 This Model only describes the characteristics of a typical product.
* In all cases, the current data sheet information for a given product
* is the final design guideline and the only actual performance
* specification. Although this Model can be a useful tool to evaluate
* the product performance, it cannot simulate the exact product performance
* under all conditions and it is also not intended to replace
* bread-boarding for final verification.
* 2. IMPORTANT NOTICE
* 2.1 Infineon Technologies AG (“Infineon”) is not and cannot be aware of the
* specific application of the Infineon’s Model by User. However, Model may
* from time to time be used by User in potentially harmful and/or life-
* endangering applications such as traffic, logistic, medical, nuclear
* or military applications or in other applications where failure of the
* Model may predictably cause damage to persons’ life or health or to
* property (hereinafter "Critical Applications").
* 2.2 User acknowledges that Infineon has not specifically designed or
* qualified the Model for Critical Applications that the Model may contain
* errors and bugs and that User is required to qualify the Model for
* Critical Applications pursuant to the applicable local quality, safety
* and legal requirements before permitting or giving access to any such use.
* 3. CONFIDENTIAL INFORMATION
* User shall treat ideas, concepts and information incorporated in the
* Model, the documentation and the content of this Terms of Use (together
* hereinafter "Confidential Information") confidential, not disclose it to
* any third party unless otherwise agreed in writing between User and
* Infineon, not use it for any other purposes than using the Model for
* simulation and testing purposes only.
* 4. WARRANTY
* 4.1 User acknowledges that the Model is provided by Infineon under this Terms
* of Use is provided free of charge and "AS IS" without any warranty or
* liability of any kind and Infineon hereby expressly disclaims any
* warranties or representations, whether express, implied, statutory or
* otherwise, including but not limited to warranties of workmanship,
* merchantability, fitness for a particular purpose, defects in the
* Model, or non-infringement of third parties intellectual property rights.
* 4.2 Infineon reserves the right to make corrections, deletions, modifications,
* enhancements, improvements and other changes to the Model at any time
* or to move or discontinue any Model without notice.
* 5. LIABILITY
* 5.1 Nothing in this Terms of Use shall limit or exclude Infineon's liability
* under mandatory liability laws, for injuries to life, body or health,
* for fraudulent concealment of defects in the software, or in cases
* of Infineon's intentional misconduct or gross negligence.
* 5.2 Without prejudice to Sections 5.1, in cases of Infineon's slight
* negligent breach of obligations that restrict essential rights or duties
* arising from the nature of this Terms of Use in a way that there is a
* risk of non-achievement of the purpose of this Terms of Use or of an
* obligation whose observance User regularly may trust in and whereas
* compliance with only makes proper execution of this Terms of Use
* possible, Infineon's liability shall be limited to the typically,
* foreseeable damage.
* 5.3 Without prejudice to Sections 8.1 and 8.2, Infineon's liability under
* this Agreement shall be excluded in all other cases.
* 6. EXPORT REGULATIONS
* The User shall comply with all applicable national and international
* laws and regulations, in particular the applicable export control
* regulations and sanction programs. The User also agrees not to
* export, re-export or transfer any software or technology developed
* with or using information, software or technology offered by Infineon,
* in violation of any applicable laws or regulations of the competent
* authorities. Further, the User shall neither use any products,
* information, software and technology offered by Infineon in or in
* connection with nuclear technology or weapons of mass destruction
* (nuclear, biological or chemical) and carriers thereof nor supply
* military consignees.
* 7. TERMINATION OF USE PERMIT
* If the User violates these Terms of Use, such User’s permit to use
* this Model terminates automatically. In addition, Infineon may
* terminate the User’s permit to use this Model at its discretion and
* at any time regardless of any violation of these Terms of Use. In
* any of the foregoing events, the User is obliged to immediately destroy
* any content that has been downloaded or printed from Infineon’s website.
* 8. MISCELLANEOUS
* 8.1 These Terms of Use are subject to the laws of the Federal Republic
* of Germany with the exception of the United Nations on Purchase
* Contracts on the International Sale of Goods dated April 11, 1980 (CISG).
* The exclusive place of jurisdiction is Munich, Germany.
* 8.2 Should any provision in these Terms of Use be or become invalid, the
* validity of all other provisions or agreements shall remain unaffected
* thereby.
.SUBCKT IR2153 LO HO COM RT CT VCC VB VS
R_CT CT COM 1E12
R_RT RT COM 1E12
R_HO HO VS 1E12
R_LO LO COM 1E12
R_VB VB VS 1E12
R_VCC VCC COM 1E12
R_VS VS COM 1E12
R_DT DT COM 1M
C_DT DT COM 1P
X_GD_TEMPLATE LO HO COM RT CT VCC VB VS DT IR2153_GD_TEMPLATE
.ENDS IR2153
.SUBCKT IR2153_GD_TEMPLATE LO HO COM RT CT VCC VB VS DT PARAMS: HB_EN=1 SHT_EN=1 P_OFFSET_DT=1.2E-06 P_SLOPE_DT=5.94E-10 P_SD_D=
+ 9.414285714285714E-08 P_TH_SD_UP=3.1 P_TH_SD_DW=0.6 P_C_SD_LPF=1.4476482730108395E-10 P_C_TPD=7.2125E-08 P_TH_TPD=0.5042766317
+ P_C_PW_MIN=1E-10 P_TH_HIN_OFF=0.6 P_TH_LIN_OFF=0.6 P_TH_HIN_ON=2.4 P_TH_LIN_ON=2.4 P_R_HIN_CL=799999.9999999999 P_R_LIN_CL=
+ 799999.9999999999 P_C_GATE=1E-12 P_RBOND_NMOS=0.01 P_RBOND_PMOS=0.01 P_LO_VGS_NMOS=4.5 P_LO_VGS_PMOS=4.7 P_LPMOS_LAMDA=0.051
+ P_LPMOS_KP=1.6E-05 P_LNMOS_LAMDA=0.01 P_LNMOS_KP=4.1E-05 P_HO_VGS_NMOS=4.5 P_HO_VGS_PMOS=4.7 P_HPMOS_LAMDA=0.051 P_HPMOS_KP=1.6E-05
+ P_HNMOS_LAMDA=0.01 P_HNMOS_KP=4.1E-05 P_VCC_UVH=9 P_VCC_UVL=8 P_VB_UVL=10.9 P_VB_UVH=11.1 P_R_UV_D_H=1428.5714285714287 P_R_UV_D_L=
+ 1428.5714285714287 P_VCC_MIN=8 P_IQ_VCC_MIN=7.5E-05 P_VB_MIN=8 P_IQ_VB_MIN=0.0 P_VCC_MAX=12 P_IQ_VCC_MAX=0.0005 P_VB_MAX=12
+ P_IQ_VB_MAX=3E-05 P_V_LEAK=600 P_I_LEAK=1E-06 P_R_BSD=170 P_N_BSD=3.4439108996145498 P_IS_BSD=1E-17
X_RT_VCC_D RT VCC IR2153_ESD_DIO PARAMS: P_V_BV=0.3 P_I_BV=1M
X_COM_RT_D COM RT IR2153_ESD_DIO PARAMS: P_V_BV=0.3 P_I_BV=1M
X_CT_VCC_D CT VCC IR2153_ESD_DIO PARAMS: P_V_BV=0.3 P_I_BV=1M
X_COM_CT_D COM CT IR2153_ESD_DIO PARAMS: P_V_BV=0.3 P_I_BV=1M
X_CL_VCC VCC COM IR2153_CL_DIO PARAMS: P_V_BV=15.6 P_I_BV=5M
X_CL_VB VB VS IR2153_CL_DIO PARAMS: P_V_BV=25 P_I_BV=5M
G_BSD VCC VB VALUE={ TABLE(V(VCC,VB), 0,0, 0.5,0,0.6,0,0.65,250M,15,500M)}
XOSC_INPUT_STAGE VCC COM VCC_UV CT RT HIN_DIG LIN_DIG VB VS IR2153_OSC_INPUT_STAGE
XOSC_DEADTIME LIN_DT_DIG HIN_DT_DIG LIN_DIG HIN_DIG VCC COM DT IR2153_OSC_DEADTIME PARAMS: P_SLOPE_DT={P_SLOPE_DT} P_OFFSET_DT=
+ {P_OFFSET_DT} HB_EN={HB_EN} SHT_EN = {SHT_EN}
E_SD_DD SD_DD 0 VALUE={1}
X_HO_STAGE HO HIN_DT_DIG VCC_UV VB_UV SD_DD VB VS IR2153_HO_STAGE PARAMS: P_RBOND_PMOS={P_RBOND_PMOS} P_RBOND_NMOS={P_RBOND_NMOS}
+ P_C_GATE={P_C_GATE} P_HO_VGS_PMOS={P_HO_VGS_PMOS} P_HPMOS_LAMDA={P_HPMOS_LAMDA} P_HPMOS_KP={P_HPMOS_KP} P_HO_VGS_NMOS=
+ {P_HO_VGS_NMOS} P_HNMOS_LAMDA={P_HNMOS_LAMDA} P_HNMOS_KP={P_HNMOS_KP}
X_LO_STAGE LO LIN_DT_DIG VCC_UV SD_DD VCC COM IR2153_LO_STAGE PARAMS: P_RBOND_PMOS={P_RBOND_PMOS} P_RBOND_NMOS={P_RBOND_NMOS}
+ P_C_GATE={P_C_GATE} P_LO_VGS_PMOS={P_LO_VGS_PMOS} P_LPMOS_LAMDA={P_LPMOS_LAMDA} P_LPMOS_KP={P_LPMOS_KP} P_LO_VGS_NMOS=
+ {P_LO_VGS_NMOS} P_LNMOS_LAMDA={P_LNMOS_LAMDA} P_LNMOS_KP={P_LNMOS_KP}
X_UV_DETECT VCC_UV VB_UV VCC VB COM VS IR2153_UV_DETECT PARAMS: P_VB_UVL={P_VB_UVL} P_VB_UVH={P_VB_UVH} P_R_UV_D_H={P_R_UV_D_H}
+ P_VCC_UVL={P_VCC_UVL} P_VCC_UVH={P_VCC_UVH} P_R_UV_D_L={P_R_UV_D_L}
X_CC_EMULATOR VCC COM VB VS VCC_UV IR2153_CC_EMULATOR PARAMS: P_VB_MIN={P_VB_MIN} P_VCC_MIN={P_VCC_MIN} P_IQ_VB_MIN={P_IQ_VB_MIN}
+ P_IQ_VCC_MIN={P_IQ_VCC_MIN} P_I_LEAK={P_I_LEAK} P_V_LEAK={P_V_LEAK} P_VB_MAX={P_VB_MAX} P_VCC_MAX={P_VCC_MAX} P_IQ_VB_MAX=
+ {P_IQ_VB_MAX} P_IQ_VCC_MAX={P_IQ_VCC_MAX}
.ENDS IR2153_GD_TEMPLATE
.SUBCKT IR2153_OSC_INPUT_STAGE VCC COM VCC_UV CT RT HIN_DIG LIN_DIG VB VS
E_TH_LOW TH_LOW 0 VALUE= {V(VCC,COM)*(2.1/12)}
E_TH_MID TH_MID 0 VALUE= {V(VCC,COM)*(4.1/12)}
E_TH_HIGH TH_HIGH 0 VALUE= {V(VCC,COM)*(7.93/12)}
G_RT_UP VCC RT VALUE= {V(VCC,RT)/100 * IF(V(RT_DIG)>0.5,1,0)}
G_RT_DW RT COM VALUE= {V(RT,COM)/100 * IF(V(RT_DIG)>0.5,0,1)}
X_IN CT IN_DIG COM TH_HIGH TH_MID VCC_UV IR2153_STP_IDEAL1
X_SD CT SD_DIG_AUX COM TH_MID TH_LOW VCC_UV IR2153_STP_IDEAL1
X_SD_DELAY SD_DIG_AUX SD_DIG IR2153_RC_DELAY_10 PARAMS: P_C_DELAY = 9.428557142857144E-08 P_TH_TPD = 0.5
E_RT_DIG RT_DIG 0 VALUE= {IF(V(IN_DIG)>0.5, 0, 1)* V(VCC_UV)}
E_HIN_DIG HIN_DIG 0 VALUE={IF(V(VB,VS)>=4,1,0)*V(HIN_DIG1)}
E_HIN_DIG1 HIN_DIG1 0 VALUE= {IF(V(IN_DIG)>0.5,1,0) * IF(V(SD_DIG)>0.5,1,0)}
E_LIN_DIG LIN_DIG 0 VALUE= {IF(V(IN_DIG)>0.5,0,1) * IF(V(SD_DIG)>0.5,1,0)}
G_CT_BIAS CT COM VALUE={TABLE( V(CT,COM),0,0,10M,1)*0.001U*V(VCC_UV)}
G_CT_PULLDOWN CT COM VALUE={TABLE( V(CT,COM),0,0,10M,700U)* IF(V(VCC_UV)>0.5,0,1)}
.ENDS IR2153_OSC_INPUT_STAGE
.SUBCKT IR2153_OSC_DEADTIME LIN_DT_DIG HIN_DT_DIG LIN_DIG HIN_DIG VCC COM DT PARAMS: HB_EN=1 SHT_EN=0.0 P_SLOPE_DT=2.43236451E-05
+ P_OFFSET_DT=5.4E-07 P_I_DT=1E-06 P_C_DT=10P P_TH_UP=0.5
E_VCC_1V VCC_1V 0 VALUE={TABLE( V(VCC,COM) , 0,0 , 3,0 , 6,1 )}
G_DT VCC DT VALUE={TABLE( V(VCC,DT) , 0,0 , 10M,{P_I_DT} )}
E_HIN_DT HIN_DT_DIG 0 VALUE={IF( V(HON) > {P_TH_UP} , 1.0 , 0.0 )}
E_LIN_DT LIN_DT_DIG 0 VALUE={IF( V(LON) > {P_TH_UP} , 1.0 , 0.0 )}
E_1 LIN_DIG_INV 0 VALUE={1- V(LIN_DIG)}
E_2 HIN_DIG_INV 0 VALUE={1- V(HIN_DIG)}
G_H_DT VCC_1V HON VALUE={TABLE( V(VCC_1V,HON) , 0,0 , 10M, I_DT( V(DT,COM) ) )}
C_H_DT HON 0 {P_C_DT}
R_H_DT HON 0 1E8
S_H_DT HON 0 HIN_DIG_INV 0 IR2153_DT_SW
G_L_DT VCC_1V LON VALUE={TABLE( V(VCC_1V,LON) , 0,0 , 10M, I_DT( V(DT,COM) ) )}
C_L_DT LON 0 {P_C_DT}
R_L_DT LON 0 1E8
S_L_DT LON 0 LIN_DIG_INV 0 IR2153_DT_SW
.FUNC I_DT(V_DT) {{P_C_DT} * {P_TH_UP} / ({P_SLOPE_DT}/{P_I_DT}*V_DT + {P_OFFSET_DT})}
.MODEL IR2153_DT_SW VSWITCH RON=1 ROFF=100MEG VON=0.8 VOFF=0.2
.ENDS IR2153_OSC_DEADTIME
.SUBCKT IR2153_INPUT_STAGE LIN_DD HIN_DD SD_DD LIN HIN SD COM PARAMS: P_SD_D=5E-08 P_TH_SD_UP=2.1 P_TH_SD_DW=1.1 P_C_TPD=1.9E-07
+ P_TH_TPD=10E-9 P_TH_HIN_OFF=0.9 P_TH_LIN_OFF=0.9 P_TH_HIN_ON=2.1 P_TH_LIN_ON=2.1 P_C_PW_MIN=42E-9 P_C_SD_LPF=1E-9
X_SD_TH SD SD_DIG COM IR2153_STP_IDEAL PARAMS: P_TH_UP={P_TH_SD_UP} P_TH_DW={P_TH_SD_DW}
X_SD_LPF SD_DIG SD_LPF_DIG IR2153_ADV_FILTER PARAMS: P_C_DELAY = {P_C_SD_LPF}
X_SD_DD SD_LPF_DIG SD_DD IR2153_RC_DELAY_10 PARAMS: P_C_DELAY = {P_SD_D}
X_HIN_TH HIN HIN_DIG COM IR2153_STP_IDEAL PARAMS: P_TH_UP={P_TH_HIN_ON} P_TH_DW={P_TH_HIN_OFF}
X_HIN_LPF HIN_DIG HIN_LPF_DIG IR2153_ADV_FILTER PARAMS: P_C_DELAY = {P_C_PW_MIN}
X_HIN_DD HIN_LPF_DIG HIN_DD IR2153_RC_DELAY_10 PARAMS: P_C_DELAY = {P_C_TPD} P_TH_TPD = {P_TH_TPD}
X_LIN_TH LIN LIN_DIG COM IR2153_STN_IDEAL PARAMS: P_TH_UP={P_TH_LIN_ON} P_TH_DW={P_TH_LIN_OFF}
X_LIN_LPF LIN_DIG LIN_LPF_DIG IR2153_ADV_FILTER PARAMS: P_C_DELAY = {P_C_PW_MIN}
X_LIN_DD LIN_LPF_DIG LIN_DD IR2153_RC_DELAY_10 PARAMS: P_C_DELAY = {P_C_TPD} P_TH_TPD = {P_TH_TPD}
.ENDS IR2153_INPUT_STAGE
.SUBCKT IR2153_OVC_DETECT ITRIP RFE OVC_OUT_CTRL VCC_UV COM PARAMS: P_TH_OVC_UP=0.445 P_TH_OVC_DW=0.375 P_C_ITRIP_LPF=330E-9
+ P_I_TRIP=2.8E-06 P_TH_RFE_UP=5.2 P_TH_RFE_DW=3.2 P_R_RFE_ON=45 P_C_ITRIP_TO_RFE=1E-9 P_C_ITRIP_TO_OUT=1E-9 P_TH_TPD_ITRIP_TO_RFE=0
R_ITRIP ITRIP COM 800K
X_ITRIP ITRIP OVC_DIG COM IR2153_STP_IDEAL PARAMS: P_TH_UP={P_TH_OVC_UP} P_TH_DW={P_TH_OVC_DW}
X_OVC_LPF OVC_DIG OVC_LPF_DIG IR2153_ADV_FILTER PARAMS: P_C_DELAY = {P_C_ITRIP_LPF}
X_ITRIP_TO_RFE OVC_LPF_DIG RFE_CTRL1 IR2153_RC_DELAY_10 PARAMS: P_C_DELAY = {P_C_ITRIP_TO_RFE} P_TH_TPD={P_TH_TPD_ITRIP_TO_RFE}
X_ITRIP_TO_OUT OVC_LPF_DIG OVC_DD IR2153_RC_DELAY_10 PARAMS: P_C_DELAY = {P_C_ITRIP_TO_OUT}
G_RFE RFE COM VALUE {(V(RFE,COM)/{P_R_RFE_ON})*V(RFE_CTRL)}
X_RFE_TH RFE RFE_DIG COM IR2153_STP_IDEAL PARAMS: P_TH_UP={P_TH_RFE_UP} P_TH_DW={P_TH_RFE_DW}
E_OVC_PLS OVC_PLS 0 VALUE={IF( (V(OVC_DD) > 0.5) | (V(OVC) > 0.5) , 1.0 , 0.0)}
E_OVC OVC 0 VALUE={IF( (V(OVC_PLS) > 0.5) & (V(RFE_DIG) < 0.5) , 1.0 , 0.0)}
E_OUT_CTRL OVC_OUT_CTRL 0 VALUE={V(OVC)}
E_RFE_CTRL RFE_CTRL 0 VALUE={IF( (V(VCC_UV) < 0.5) | (V(RFE_CTRL1) > 0.5) , 1.0 , 0.0 )}
.ENDS IR2153_OVC_DETECT
.SUBCKT IR2153_DEADTIME LIN_DT_DIG HIN_DT_DIG LIN HIN DT VCC COM SD_DD VCC_UV PARAMS: HB_EN=1 SHT_EN=0.0 P_SLOPE_DT=2.43236451E-05
X_LIN_DT LIN LIN_DD IR2153_RC_DELAY_10 PARAMS: P_C_DELAY = 0.3N
X_HIN_DT HIN HIN_DD IR2153_RC_DELAY_10 PARAMS: P_C_DELAY = 0.1N
E_HDT_PLS HIN_DT_PLS 0 VALUE={IF( ((V(HIN_DD) - V(LIN_DD)) > 0.1) | (V(HIN_DT_DIG) > 0.5) | ({HB_EN} < 0.5), 1.0 , 0.0 )}
E_HIN_DT HIN_DT_DIG 0 VALUE={IF( ( ((V(HIN_DT_PLS) > 0.5) & (V(LOFF) > {P_TH_UP})) | {HB_EN} < 0.5 ) & (V(HIN_DD) > 0.5 ) & V(
+ VCC_UV) > 0.5 & V(SD_DD)>0.5 , 1.0 , 0.0 )}
E_LDT_PLS LIN_DT_PLS 0 VALUE={IF( ((V(LIN_DD) - V(HIN_DD)) > 0.1) | (V(LIN_DT_DIG) > 0.5) | ({HB_EN} < 0.5) , 1.0 , 0.0 )}
E_LIN_DT LIN_DT_DIG 0 VALUE={IF( ( ((V(LIN_DT_PLS) > 0.5) & (V(HOFF) > {P_TH_UP})) | {HB_EN} < 0.5 ) & (V(LIN_DD) > 0.5 ) , 1.0 ,
+ 0.0 )}
E_SHT_H SHT_H 0 VALUE={IF( {SHT_EN} > 0.5 , V(HIN_DD) , V(HIN_DT_DIG) )}
E_SHT_L SHT_L 0 VALUE={IF( {SHT_EN} > 0.5 , V(LIN_DD) , V(LIN_DT_DIG) )}
G_H_DT VCC_1V HOFF VALUE={TABLE( V(VCC_1V,HOFF) , 0,0 , 10M, I_DT( V(DT,COM) ) )}
C_H_DT HOFF 0 {P_C_DT}
R_H_DT HOFF 0 1E8
S_H_DT HOFF 0 SHT_H 0 IR2153_DT_SW
G_L_DT VCC_1V LOFF VALUE={TABLE( V(VCC_1V,LOFF) , 0,0 , 10M, I_DT( V(DT,COM) ) )}
C_L_DT LOFF 0 {P_C_DT}
R_L_DT LOFF 0 1E8
S_L_DT LOFF 0 SHT_L 0 IR2153_DT_SW
.ENDS IR2153_DEADTIME
.SUBCKT IR2153_HO_STAGE HO HIN_DT_DIG VCC_UV VB_UV SD_DD VB VS PARAMS: P_RBOND_NMOS=10M P_RBOND_PMOS=10M P_C_GATE=1E-12
+ P_HO_VGS_PMOS=6 P_HPMOS_LAMDA=0.06 P_HPMOS_KP=60U P_HO_VGS_NMOS=6 P_HNMOS_LAMDA=0.05 P_HNMOS_KP=100U
R_HIN_DT_DD HIN_DT_DIG HIN_DT_DD 100
C_HIN_DT_DD HIN_DT_DD 0 1N
E_HIN_PLS HIN_PLS 0 VALUE {IF( (V(HIN_DT_DIG) - V(HIN_DT_DD)) > 0.1 | ((V(HGATE_DIG) > 0.5) & V(HIN_DT_DIG)>0.5), 1.0,0.0 )}
E_HGATE_DIG HGATE_DIG 0 VALUE {IF( ( V(HIN_PLS) > 0.5 & V(SD_DD) > 0.5 ) , 1.0,0.0 )}
R_HGATE HGATE_DIG HGATE 1
C_HGATE HGATE 0 {P_C_GATE}
E_HGATE_P VB HGATE_P VALUE {V(HGATE) * {P_HO_VGS_PMOS} * V(HGATE_DIG)}
E_HGATE_N HGATE_N VS VALUE {(1 - V(HGATE)) * {P_HO_VGS_NMOS} * (1 - V(HGATE_DIG))}
M_HO_PMOS HO HGATE_P VB VB IR2153_HO_PMOS
M_HO_NMOS HO HGATE_N VS VS IR2153_HO_NMOS
.MODEL IR2153_HO_PMOS PMOS (LEVEL=1 VTO=-1 CGSO=100P W=1M L=1U RB=1 RG=10 RS=10M RD={P_RBOND_PMOS} LAMBDA={P_HPMOS_LAMDA} KP=
+ {P_HPMOS_KP} )
.MODEL IR2153_HO_NMOS NMOS (LEVEL=1 VTO=1 CGSO=100P W=1M L=1U RB=1 RG=10 RS=10M RD={P_RBOND_NMOS} LAMBDA={P_HNMOS_LAMDA} KP=
+ {P_HNMOS_KP} )
.ENDS IR2153_HO_STAGE
.SUBCKT IR2153_LO_STAGE LO LIN_DT_DIG VCC_UV SD_DD VCC COM PARAMS: P_RBOND_NMOS=10M P_RBOND_PMOS=10M P_C_GATE=1E-12 P_LO_VGS_PMOS=6
+ P_LPMOS_LAMDA=0.06 P_LPMOS_KP=60U P_LO_VGS_NMOS=6 P_LNMOS_LAMDA=0.05 P_LNMOS_KP=100U
E_LGATE_DIG LGATE_DIG 0 VALUE {IF( (V(VCC_UV) > 0.5 & V(LIN_DT_DIG) > 0.5 & V(SD_DD) > 0.5 ), 1.0,0.0 )}
R_LGATE LGATE_DIG LGATE 1
C_LGATE LGATE 0 {P_C_GATE}
E_LGATE_P VCC LGATE_P VALUE {V(LGATE) * {P_LO_VGS_PMOS} * V(LGATE_DIG)}
E_LGATE_N LGATE_N COM VALUE {(1 - V(LGATE)) * {P_LO_VGS_NMOS} * (1 - V(LGATE_DIG))}
M_LO_PMOS LO LGATE_P VCC VCC IR2153_LO_PMOS
M_LO_NMOS LO LGATE_N COM COM IR2153_LO_NMOS
.MODEL IR2153_LO_PMOS PMOS (LEVEL=1 VTO=-1 CGSO=100P W=1M L=1U RB=1 RG=10 RS=10M RD={P_RBOND_PMOS} LAMBDA={P_LPMOS_LAMDA} KP=
+ {P_LPMOS_KP} )
.MODEL IR2153_LO_NMOS NMOS (LEVEL=1 VTO=1 CGSO=100P W=1M L=1U RB=1 RG=10 RS=10M RD={P_RBOND_NMOS} LAMBDA={P_LNMOS_LAMDA} KP=
+ {P_LNMOS_KP} )
.ENDS IR2153_LO_STAGE
.SUBCKT IR2153_UV_DETECT VCC_UV VB_UV VCC VB COM VS PARAMS: P_VB_UVL=7 P_VB_UVH=8 P_R_UV_D_H=142857 P_VCC_UVL=8 P_VCC_UVH=9
+ P_R_UV_D_L=71428
X_VB_UV VB VB_UV_DIG VS IR2153_STP_IDEAL PARAMS: P_TH_UP={P_VB_UVH} P_TH_DW={P_VB_UVL}
E_VB_UVL VB_UVL 0 VALUE {IF( V(VB,VS) < {P_VB_UVL} , 0.0 , 1.0 )}
R_VB_UVL VB_UVL VB_UVL_LPF {P_R_UV_D_H}
C_VB_UVL VB_UVL_LPF 0 1P
E_VB_UVL_PLS VB_UVL_PLS 0 VALUE {IF( V(VB_UVL_LPF) < 0.5 | V(VB_UV) < 0.5 , 0.0 , 1.0 )}
E_VB_UV VB_UV 0 VALUE {IF( V(VB_UV_DIG) < 0.5 & V(VB_UVL_PLS) < 0.5 , 0.0 , 1.0 )}
X_VCC_UV VCC VCC_UV_DIG COM IR2153_STP_IDEAL PARAMS: P_TH_UP={P_VCC_UVH} P_TH_DW={P_VCC_UVL}
E_VCC_UVL VCC_UVL 0 VALUE {IF( V(VCC,COM) < {P_VCC_UVL} , 0.0 , 1.0 )}
R_VCC_UVL VCC_UVL VCC_UVL_LPF {P_R_UV_D_L}
C_VCC_UVL VCC_UVL_LPF 0 1P
E_VCC_UVL_PLS VCC_UVL_PLS 0 VALUE {IF( V(VCC_UVL_LPF) < 0.5 | V(VCC_UV) < 0.5 , 0.0 , 1.0 )}
E_VCC_UV VCC_UV 0 VALUE {IF( V(VCC_UV_DIG) < 0.5 & V(VCC_UVL_PLS) < 0.5 , 0.0 , 1.0 )}
.ENDS IR2153_UV_DETECT
.SUBCKT IR2153_CC_EMULATOR VCC COM VB VS VCC_UV PARAMS: P_VB_MIN=10 P_VCC_MIN=10 P_IQ_VB_MIN=100U P_IQ_VCC_MIN=500U P_I_LEAK=1.0U
+ P_V_LEAK=650 P_VB_MAX=10 P_VCC_MAX=10 P_IQ_VB_MAX=100U P_IQ_VCC_MAX=500U
G_QB VB VS VALUE {TABLE(V(VB,VS) , 0,0 , 0.1,1U , 1,10U , {P_VB_MIN},{P_IQ_VB_MIN} , {P_VB_MAX},{P_IQ_VB_MAX} ) * V(VCC_UV)}
R_QB VB VS 1E12
G_QCC VCC COM VALUE {TABLE(V(VCC,COM) , 0,0 , 0.1,1U , 1,10U , {P_VCC_MIN},{P_IQ_VCC_MIN} ,8, {P_IQ_VCC_MIN}, {P_VCC_MAX},
+ {P_IQ_VCC_MAX} )}
R_QCC VCC COM 1E12
G_VB_LEAK VS COM VALUE {TABLE(V(VB,COM) , 0,0 , {P_V_LEAK},{P_I_LEAK})}
R_VB_LEAK VS COM 1E12
.ENDS IR2153_CC_EMULATOR
.SUBCKT IR2153_CL_DIO C A PARAMS: P_V_BV=5 P_I_BV=1
G_CL_DIO C A VALUE {TABLE(V(C,A) , 0,0 , {P_V_BV},0 , {P_V_BV}*1.002,{P_I_BV} , 10*{P_V_BV}, 100*{P_I_BV} )}
C_CL_DIO C A 10F
R_CL_DIO C A 1E12
.ENDS IR2153_CL_DIO
.SUBCKT IR2153_ESD_DIO A C PARAMS: P_V_BV=5 P_I_BV=1
G_ESD_DIO A C VALUE {TABLE(V(A,C) , 0,0 , {P_V_BV}*1.01,0 , {P_V_BV}*1.02,{P_I_BV} , 10*{P_V_BV}, 100*{P_I_BV} )}
C_ESD_DIO A C 10F
R_ESD_DIO A C 1E12
.ENDS IR2153_ESD_DIO
.SUBCKT IR2153_RC_DELAY_10 IN OUT PARAMS: P_C_DELAY = 60E-9 P_TH_TPD = 0.5
X_D1 IN D1 IR2153_RC_DELAY_5 PARAMS: P_C_DELAY = {P_C_DELAY} P_TH_TPD = {P_TH_TPD}
X_D2 D1 OUT IR2153_RC_DELAY_5 PARAMS: P_C_DELAY = {P_C_DELAY} P_TH_TPD = {P_TH_TPD}
.ENDS IR2153_RC_DELAY_10
.SUBCKT IR2153_RC_DELAY_5 IN OUT PARAMS: P_C_DELAY = 60E-9 P_TH_TPD = 0.5
X_D1 IN D1 IR2153_RC_DELAY_BASE PARAMS: P_C_DELAY = {P_C_DELAY} P_TH_TPD = {P_TH_TPD}
X_D2 D1 D2 IR2153_RC_DELAY_BASE PARAMS: P_C_DELAY = {P_C_DELAY} P_TH_TPD = {P_TH_TPD}
X_D3 D2 D3 IR2153_RC_DELAY_BASE PARAMS: P_C_DELAY = {P_C_DELAY} P_TH_TPD = {P_TH_TPD}
X_D4 D3 D4 IR2153_RC_DELAY_BASE PARAMS: P_C_DELAY = {P_C_DELAY} P_TH_TPD = {P_TH_TPD}
X_D5 D4 OUT IR2153_RC_DELAY_BASE PARAMS: P_C_DELAY = {P_C_DELAY} P_TH_TPD = {P_TH_TPD}
.ENDS IR2153_RC_DELAY_5
.SUBCKT IR2153_RC_DELAY_BASE IN OUT PARAMS: P_C_DELAY = 60E-9 P_TH_TPD = 0.5
R_DELAY IN IN_DEL 1
C_DELAY IN_DEL 0 {P_C_DELAY}
E_DELAY OUT 0 VALUE={IF( V(IN_DEL) > {P_TH_TPD} , 1.0,0.0 )}
.ENDS IR2153_RC_DELAY_BASE
.SUBCKT IR2153_ADV_FILTER IN OUT PARAMS: P_C_DELAY = 60E-9 P_TH_TPD = 0.5
R_RISE IN IN_DEL 1
C_RISE IN_DEL 0 {P_C_DELAY}
X_CMP IN_DEL OUT 0 IR2153_STP_IDEAL PARAMS: P_TH_UP=0.999 P_TH_DW=0.001
.ENDS IR2153_ADV_FILTER
.SUBCKT IR2153_STP_IDEAL1 IN OUT GND UP DW VCC_UV PARAMS: P_TH_UP=0.9 P_TH_DW=0.1
E_OUTP OUTP 0 VALUE={IF( V(IN,GND)>=V(UP) | V(OUTN)<0.5 , 1,0 )*V(VCC_UV)}
E_OUTN OUTN 0 VALUE={IF( V(IN,GND)<=V(DW) | V(OUTP)<0.5 , 1,0 )}
E_OUT OUT 0 VALUE={V(OUTP)}
.ENDS IR2153_STP_IDEAL1
.SUBCKT IR2153_STP_IDEAL IN OUT GND PARAMS: P_TH_UP=0.9 P_TH_DW=0.1
E_OUTP OUTP 0 VALUE={IF( V(IN,GND)>={P_TH_UP} | V(OUTN)<0.5 , 1,0 )}
E_OUTN OUTN 0 VALUE={IF( V(IN,GND)<={P_TH_DW} | V(OUTP)<0.5 , 1,0 )}
.SUBCKT IR2153_STN_IDEAL1 IN OUT GND UP DW PARAMS: P_TH_UP=0.9 P_TH_DW=0.1
E_OUTP OUTP 0 VALUE={IF( V(IN,GND)>= V(UP) | V(OUTN)<0.5 , 1,0 )}
E_OUTN OUTN 0 VALUE={IF( V(IN,GND)<= V(DW) | V(OUTP)<0.5 , 1,0 )}
E_OUT OUT 0 VALUE={V(OUTN)}
.ENDS IR2153_STN_IDEAL1
.SUBCKT IR2153_STN_IDEAL IN OUT GND PARAMS: P_TH_UP=0.9 P_TH_DW=0.1
* Model IR2153
* (C)TAU 2009, (C) KaV 2010
.subckt IR2153 Vcc Rt Ct COM VB HO VS LO
R5 ARB3_N1 Rt 100
Rdead ARB3_N2 ARB4_OUT 1k
Cdead ARB3_N2 COM 1.8n
RdlyH CdlyH_P ARB5_OUT 1k
CdlyH CdlyH_P COM 910p
RdlyL CdlyL_P ARB3_OUT 1k
CdlyL CdlyL_P COM 910p
GARB1 Vcc COM VALUE={(75u+500u*(V(Vcc,COM)>8)+5m*exp(10*(V(Vcc,COM)-15.6)))*(V(Vcc,COM)>1)}
* Micropower startup VCC supply current 75u
* Quiescent VCC supply current 500u;
* VCC zener clamp voltage 15.6V On ICC = 5mA
EARB2 ARB3_N1 COM VALUE={V(ARB7_N1,COM)*(((V(Ct,COM)<(V(ARB7_N1,COM)*2/3)) & (V(ARB3_N1,COM)>4)) | ((V(Ct,COM)<(V(ARB7_N1,COM)/3)) & (V(ARB3_N1,COM)<3)))}
EARB3 ARB3_OUT COM VALUE={5*( V(ARB3_N1,COM)>8 & V(ARB3_N2,COM)>2.5 )* (V(ARB3_N3,COM)>2.5)}
EARB4 ARB4_OUT COM VALUE={5*( V(ARB3_N1,COM)>0.1 & V(Ct,COM)>V(ARB3_N1,COM)/3)}
EARB5 ARB5_OUT COM VALUE={5*( V(ARB3_N1,COM)<8 & V(ARB3_N2,COM)<2.5 & V(ARB7_N1,COM)>1)}
EARB6 ARB7_N1 COM VALUE={V(Vcc,COM)*((V(Vcc,COM)>8 & V(ARB7_N1,COM)>0.2)|(V(Vcc,COM)>9 & V(ARB7_N1,COM)<0.1))}
* VCC undervoltage lockout Hysteresis
EARB7 ARB3_N3 COM VALUE={4*( V(Ct,COM)>V(ARB7_N1,COM)/6)} ; * for Inhibit LO in SD mode
GARB8 Ct COM VALUE={(V(ARB7_N1,COM)<1)*0.8m*( V(Ct,COM)>0.1)}; * ICTUV UV-mode CT pin pulldown current 0.8mA
.IC V(Ct)=0 V(LO)=0; * V(Vs)=0; * V(COM)
S1 HO VS CdlyH_P COM SVL
S2 VB HO CdlyH_P COM SVH
S3 Vcc LO CdlyL_P COM SVH
S4 LO COM CdlyL_P COM SVL
D1 LO Vcc DM
D2 COM LO DM
D3 HO VB DM
D4 VS HO DM
.MODEL SVH VSWITCH (RON=35 ROFF=1Meg VON=2.5 VOFF=2.45)
.MODEL SVL VSWITCH (RON=18 ROFF=.1meg VON=2.45 VOFF=2.5)
.model DM D(Ron=1 Roff=1Meg Vfwd=.5 Vrev=25)
.ends IR2153
Обе модели рабочие, сам проверял. Временной шаг надо установить
-Получатся крутые фронты и чёткое мёртвое время.
Message 1 of 1
(3,915 Views)
