Multisim and Ultiboard
Error: RefDes 'u2', element 'xu2': Unable to interpret 'u2_open_11'
I made a new component (LM565) using "tools" in multisim. I don't know what this error is all about but I'm guessing it has something to do with the component that I made. Does anyone understand this error and know how to fix it?
I think I should note that I followed an online guide for making the custom component (LM565).
Here is the circuit that features an FSK modulator and demodulator that uses an LM 565.which shows the subject (error).
Message 1 of 10
(2,925 Views)
Выкладывайте в формате "ms", плиз.
Message 2 of 10
(2,902 Views)
Sorry, it seems I can't edit it anymore. By 'ms', do you mean the file itself? If so, here it is.
Message 3 of 10
(2,888 Views)
Спасибо!
Message 4 of 10
(2,866 Views)
Посмотрел вашу модель, сомневаюсь весьма, что она правильная. Это издевательства преподов, возьмите более современный аналог и вставьте его в схему
Message 5 of 10
(2,863 Views)
Thank you, I'll keep that in mind. The same thing actually happened for a previous experiment where we just searched for another circuit online.
Message 6 of 10
(2,845 Views)
Здоровья!
Попробуйте эту модель, взята из надёжного источника.
* CD4046B Phase-locked Loop
* Model copyright of Geoff Western (aka Alec-T). May be copied freely for private non-commercial use.
.SUBCKT CD4046Bg C1a C1b CompIn Inh R1 R2 SigIn VCOin Vdd Vss Dem PC1out PC2out Phaseout VCOout Zen
A1 N004 e 0 0 0 0 N007 0 SCHMITT vt=0 vh=1m td=50n
A2 CompIn e 0 0 0 0 N012 0 SCHMITT vt=0 vh=1m td=50n
A6 0 N007 0 N012 0 N016 N013 0 XOR
S3 PhaseOut Vdd N006 Vss ms
S4 Vss PhaseOut N003 Vss ms
S1 PC2out Vdd N002 Vss ms
S2 Vss PC2out N005 Vss ms
S5 PC1out Vdd N013 Vss ms
S6 Vss PC1out N016 Vss ms
R2 Vdd e 500k
R3 e Vss 500k
A7 0 N002 0 N005 0 N006 N003 0 OR
A4 0 N007 0 N012 0 0 N009 0 AND td=100n
A3 Vdd 0 N007 0 N009 0 N002 0 DFLOP
A5 Vdd 0 N012 0 N009 0 N005 0 DFLOP
D3 Vss Zen Zd
M3 R2 R2 N001 N001 mp2
M6 N008 R2 N001 N001 mp2
M4 R2 VCOin R1 R1 mn2
A11 N015 N014 0 0 0 N018 N019 0 SRFLOP td=50n
A9 C1a e 0 0 0 0 N014 0 SCHMITT vt=0 vh=1m td=50n
A10 C1b e 0 0 0 0 N015 0 SCHMITT vt=0 vh=1m td=50n
M5 N017 VCOin Dem Dem mn2
S13 VCOout Vdd N010 Vss ms
S14 Vss VCOout N011 Vss ms
S8 N017 Vdd ni 0 ms
S7 N001 Vdd ni 0 ms
A8 Inh e 0 0 0 ni 0 0 SCHMITT vt=0 vh=1m td=50n
S9 C1a N008 N010 Vss ms
S10 Vss C1a N011 Vss ms
S11 C1b N008 N011 Vss ms
S12 Vss C1b N010 Vss ms
D1 Vss C1a D
D2 Vss C1b D
A12 0 N018 0 ni 0 0 N011 0 AND
A13 0 N019 0 ni 0 0 N010 0 AND
R4 e Inh 10meg
M2 N004 SigIn Vss Vss mn1
M1 N004 SigIn Vdd Vdd mp1
R1 N004 SigIn 250k
.lib standard.dio
.lib standard.mos
.model D D
.model Zd D(Is=2n Rs=.5 Cjo=200p nbv=3 bv=5.2 Ibv=1m Vpk=5.2)
.model ms sw(ron=300 roff=1e7 vt=.5 vh=0)
.model mn1 nmos(vto=1 kp=6e-5)
.model mp1 pmos(vto=-1 kp=6e-5)
.model mn2 nmos(vto=1.8 kp=1 Rd=5)
.model mp2 pmos(vto=-1 kp=1)
.ENDS CD4046Bg
Message 7 of 10
(2,838 Views)
Ещё одна текстовая модель
* Model 74HC4046 Phase-Locked Loop with VCO
* By Valentyn Volodin
* Created 25.11.2015
.subckt 74HC4046TI PCP PC1 COMP VCOout INHIBT C1A C1B 0 VCO DEM R1 R2 PC2 SIG PC3 VCC
A1 VCC 0 isig 0 N008 0 N003 0 DFLOP Vhigh=5 Trise=10n
A2 VCC 0 icomp 0 N008 0 N009 0 DFLOP Vhigh=5 Trise=10n
A4 N003 0 isig 0 0 0 N004 0 DFLOP Vhigh=5 Trise=10n
A5 N009 0 icomp 0 0 0 N013 0 DFLOP Vhigh=5 Trise=10n
A6 N004 N003 0 0 0 0 N005 0 OR Vhigh=5 Trise=10n
A7 N009 0 0 0 N013 0 N010 0 OR Vhigh=5 Trise=10n
A3 N003 0 0 0 N009 0 N008 0 AND Vhigh=5 Trise=10n
A8 N006 0 0 0 0 0 N007 0 BUF Vhigh=5 Trise=10n
A9 N011 0 0 0 0 0 N012 0 BUF Vhigh=5 Trise=10n
R1 N005 N006 2k
R2 N010 N011 2k
C1 N006 0 10p
C2 N011 0 10p
S1 PC2 VCC N007 0 os
S2 0 PC2 N012 0 os
A10 isig 0 0 0 icomp N002 N001 0 XOR Vhigh=5 Trise=10n
S3 PC1 VCC N001 0 os
S4 0 PC1 N002 0 os
S5 PCP VCC N014 0 os
S6 0 PCP N016 0 os
A11 N007 0 0 0 N012 N016 N014 0 OR Vhigh=5 Trise=10n
D1 0 PC1 od
D2 PC1 VCC od
D3 PC2 VCC od
D4 0 PC2 od
D5 PCP VCC od
D6 0 PCP od
A12 N019 N023 0 0 0 N021 N022 0 SRFLOP Vhigh=5 Trise=10n
A13 isig 0 N020 0 0 0 N019 0 AND Vhigh=5 Trise=10n
A14 0 0 N024 0 icomp 0 N023 0 AND Vhigh=5 Trise=10n
S7 PC3 VCC N021 0 os
S8 0 PC3 N022 0 os
D7 0 PC3 od
D8 PC3 VCC od
A15 isig 0 0 0 0 N020 0 0 BUF Vhigh=5 Trise=10n Td=30n
A16 icomp 0 0 0 0 N024 0 0 BUF Vhigh=5 Trise=10n Td=30n
A17 SIG 0 0 0 0 0 isig 0 BUF Vhigh=5 Trise=10n
A18 COMP 0 0 0 0 0 icomp 0 BUF Vhigh=5 Trise=10n
A19 N028 N031 0 0 0 N032 N027 0 SRFLOP Vhigh=5 Trise=10n
V5 N015 R2 0.7
S9 0 C1A 1 0 MS
S10 0 C1B 2 0 MS
E1 N018 0 VCO 0 1
V6 N017 R1 0
A20 C1A N030 0 0 0 0 N028 0 SCHMITT Vhigh=5 Trise=10n Vt=0.6 Vh=1m
A21 C1B N030 0 0 0 0 N031 0 SCHMITT Vhigh=5 Trise=10n Vt=0.6 Vh=1m
E2 N030 0 VCC 0 0.1
D9 0 C1A ms
D10 0 C1B ms
B2 0 N025 I=(0.3981*V(VCC)+4.6147)*I(V5)**(0.59m*V(VCC)+0.9849)
B1 0 N026 I=5.5409*I(V6)**0.988
V7 N025 0 0
V8 N026 0 0
F1 0 C1A V7 1
F2 0 C1A V8 1
F3 0 C1B V7 1
F4 0 C1B V8 1
A22 2 0 0 0 0 VCOout 0 0 BUF Vhigh=5 Trise=10n
A23 0 0 N027 N029 0 2 0 0 AND Vhigh=5 Trise=10n
A24 0 0 N032 N029 0 1 0 0 AND Vhigh=5 Trise=10n
A25 INHIBT 0 0 0 0 N029 0 0 BUF Vhigh=5 Trise=10n
R6 INHIBT 0 10meg
R3 VCO 0 10meg
R4 SIG 0 10meg
R5 COMP 0 10meg
R7 N018 DEM 100
R8 N015 VCC 100
R9 N017 N018 100
.model os SW(Ron=30 Roff=10Meg Vt=2.5 Vh=-0.5)
.model od D(Ron=10 Roff=10meg Vfwd=0.6)
.model MS SW(Ron=10 Roff=1g Vt=2.5 Vh=0 Vser=0.15)
.model ms D(Ron=1 Roff=1g Vfwd=0.7)
.ends 74HC4046TI
.subckt 74HC4046ON PCP PC1 COMP VCOout INHIBT C1A C1B 0 VCO DEM R1 R2 PC2 SIG PC3 VCC
R1 N005 N006 2k
R2 N010 N011 2k
C1 N006 0 10p
C2 N011 0 10p
S2 0 PC2 N012 0 os
S4 0 PC1 N002 0 os
S6 0 PCP N016 0 os
D1 0 PC1 od
D2 PC1 VCC od
D3 PC2 VCC od
D4 0 PC2 od
D5 PCP VCC od
D6 0 PCP od
S8 0 PC3 N022 0 os
D7 0 PC3 od
D8 PC3 VCC od
A19 N027 N030 0 0 0 N031 N026 0 SRFLOP Vhigh=5 Trise=10n
V5 N015 R2 0.7
S9 0 C1A 1 0 MS
S10 0 C1B 2 0 MS
E1 N018 0 VCO 0 1
V6 N017 R1 0
A20 C1A N029 0 0 0 0 N027 0 SCHMITT Vhigh=5 Trise=10n Vt=0.3 Vh=1m
A21 C1B N029 0 0 0 0 N030 0 SCHMITT Vhigh=5 Trise=10n Vt=0.3 Vh=1m
E2 N029 0 VCC 0 0.3
D9 0 C1A ms
D10 0 C1B ms
B1 0 N025 I=I(V6)*(36-8800*I(V6))
V8 N025 0 0
F1 0 C1A V5 4.6
F2 0 C1A V8 1
F3 0 C1B V5 4.6
F4 0 C1B V8 1
A23 0 0 N026 N028 0 2 0 0 AND Vhigh=5 Trise=10n
A24 0 0 N031 N028 0 1 0 0 AND Vhigh=5 Trise=10n
A25 INHIBT 0 0 0 0 N028 0 0 BUF Vhigh=5 Trise=10n
R6 INHIBT 0 10meg
R3 VCO 0 10meg
R4 SIG 0 10meg
R5 COMP 0 10meg
R7 N018 DEM 100
R8 N015 VCC 100
R9 N017 N018 100
.ends 74HC4046ON
Message 8 of 10
(2,832 Views)
Thank you, I'll try those models.
Message 9 of 10
(2,828 Views)
Вторая модель для LTs, могут игнорироваться последние параметры (
.модель os SW (Ron = 30 Roff = 10Meg Vt = 2.5 Vh = -0.5)
.модель od D (Ron = 10 Roff = 10meg Vfwd = 0.6)
.модель MS SW (Ron = 10 Roff = 1gVt = 2.5 Vh = 0 Vser = 0.15)
.модель ms D (Ron = 1 Roff = 1g Vfwd = 0.7)
но должно работать без них...
Message 10 of 10
(2,824 Views)
