02-04-2011 08:48 AM
Hi all,
I have placed a copper area on the copper top layer. When I place IC's only very small copper area surrounding the pins is automatically removed. What I want to do is be able to remove manually parts of the copper area. How do I do this?
Thanks.
Viktar
02-04-2011 11:28 AM
1. Right click on IC and select In-Place Part Edit
2. Right click on pins and select Properties
3. Through Hole Pin Properties (SMT Pin...)>>General>>Clearances
02-04-2011 12:44 PM
Hi Viktar,
There are two ways to achieve this. As supsup noted, you can increase the clearance of the pins so that they will remove more of the copper area. The other alternative is to change the properties of the copper area so that it either automatically or manually removes these "islands".
Automatically Remove Islands
Ultiboard can automatically remove pieces of unconnected copper depending on the size of the piece of copper.
Manually Remove Islands
You can manually marks islands to be removed.
