07-25-2012 10:39 AM
I am trying to build a connector part in Ultiboard, but when I try to place holes they will not generate to be placed. I can place pins with no problem. What can I do to place holes on a part?
07-26-2012
08:35 AM
- last edited on
11-21-2025
02:37 PM
by
Content Cleaner
If you could provide your file, I will be able to assist you better. You should be able to place holes on the part by simply going to Place»Hole.
When you are creating the part, you have to add the holes to the part while you are creating it;
Creating a Custom Component in NI Ultiboard
Also, what version of Ultiboard are you using?
