07-10-2013 12:23 PM
Is there a way to parameterize hierachical blocks?
With LabVIEW, you're able to create a circuit and make it in to a sub-circuit. You can make it so that you can alter the parameters of the components inside the sub-circuit without having to open the sub-circuit, to do so. Is this possible with Multisim?
Rob
07-10-2013 02:14 PM
This functionality is not currently available. You have to navigate to the page that has the components to change their properties.
