Multisim and Ultiboard
PWM to Pulsed DC
Does anyone know of a simulated circuit that creates a PWM signal and uses it to modify a created pulsed DC signal to end up with a pulsed DC with the effective voltage of the PWM?
The PWM is +5V at 490Hz with an adjustable duty cycle that will represent +0 to +1.2V and the input pulsed DC is +5V, 18us PW and 3.6ms between pulses.
I am not an expert on this, so please excuse any errors in the description.
Thanks in advance!
(3,360 Views)
This sounds like a chopper circuit.  At 490Hz the period should be 2.041mS so I don't understand your 3.6ms between pulse.
If you are working on a buck chopper and want a 1.2V output from a 5V supply then you would want a duty cycle of 1.2/5.0 = 24% which would be an on time of 190 uS.
Below are some NI white papers talking about Co-Simulation and H-bridges.  I'd start looking through those.  The last 3 circuits are H-bridges which are more complicated than your chopper circuit but making simpler circuits once you under stand these should be straight forward.  Maybe someone has a better link to a simple half bridge or buck chopper.
Introductory Tutorial Video: Power Electronics Co-Simulation with NI Multisim and LabVIEW
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
THEN DO THIS
Introduction to Digital and Analog Co-simulation Between NI LabVIEW and NI Multisim
http://www.ni.com/white-paper/13663/en/
THEN DO THIS
How to Design and Simulate a Brushed DC Motor H-Bridge Circuit Using NI Multisim
http://www.ni.com/white-paper/13721/en/
Simple H Bridge drive for brushed motor with Utiliboard sample
http://www.ni.com/white-paper/13840/en/
H-Bridge DC Motor Controller Implementation with NI Circuit Design Suite and NI Single-Board RIO
http://www.ni.com/white-paper/14228/en/
(3,354 Views)
Thank you very much for taking the time to respond.
I
am sorry, but I am afraid that my understanding of circuits is not sufficient enough to have described my situation adequately or to interpret your detailed response.
What I am trying to figure out is a circuit which imposes the effective voltage level of a PWM onto a pulsed DC.
There are 2 inputs:
  1. Output of +5VDC PWM with 0V to +1.1VDC input to it.
  2. +5V square waveform pulsed DC with 18us PW and 277.78 PRF.
There is 1 output:
  1. Same as input B with the voltage the same level as the effective voltage of input A (actually the same voltage as the input to the PWM)
Inputs A and B represent actual inputs provided to a circuit, so the simulation would have to create them.
The 0V to +1.1VDC input to the PWM represents possible values that can change at any time, but do not vary frequently, that is it will be one value for a while and then may change.
I think that the output of the PWM would have to be smoothed to an analog signal and somehow modify the voltage of input B.
(3,323 Views)
