Multisim and Ultiboard
Not Enough Nodes Found netlist error
I am working on a project for a voltage multiplier/divider and am working off this schematic from texas instruments (I have attached a pdf of it). When I try to simulate the circuit, I get an netlist error on every LM101AD Opamp saying Not Enough Nodes Found and the circuit doesnt work as it is support to. I have attached the circuit in multisim and the original drawing. Thanks for your help, -Alex
(3,770 Views)
The reason for the error message is that there are more nodes on the opamp's model than are mapped to those nodes. This component has multiple models, and this is a problem in the database only with the default Linear Technology/LM101A model.
You can select the model in the Place a Component dialog when you place or replace a component (look for Model manuf./ID).
I've made these.changes to your file. It will now simulate without errors, but the rated capacitor blows up. I haven't looked in detail if this is what to expect (electronics is not my forte).
I've also added this to our defect tracker so we can resolve this in a future release and improve the error message.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,739 Views)
Thanks alot for your help. I just tried and it simulated without error but the capacitor blew as you said. Now I can work on that issue. Thanks, -Alex
(3,736 Views)
