11-04-2011 09:06 AM - edited 11-04-2011 09:16 AM
Can anybody help me out with this.
I am a student doing a research which involves simulating vertical surround gate field effect transistor.
I would like to know if it's possible to do so using a vertical transistor using multisim.
Below is the image of the transistors model.
If it's not possible, is it posibble to simulate the equivalent circuit which is a normal circuit which can also be done with pspice?
Thanks in advance!
04-26-2012 01:01 PM
If you can write the pspice model for it, you can simulate it. The accuracy of the simulation depends on the detail of the model.
