Multisim and Ultiboard
Multisim Live - Logic Gates not working
I noted that logic gates were added ao Multisim Live, but the AND, OR and NOR gates with 2 and 3 inputs are not working. It's not possible to insert them in the circuit.
(5,537 Views)
I too have discovered this problem with all other logic gates as well. Problem still persists.
(5,072 Views)
No solution? It's frustrating when trying to show someone how a circuit works, and you can't because you can only use 4 input gates.  Only the hand shows up when I tried to use 2-3 input and, or gates.  I tried two different browsers just in case.
(4,731 Views)
Hi to all,
I hope this helps Re: Cannot get logic gates to place on schematic.
G. Goodwin
(4,716 Views)
Hold the left mouse button down on the component for a second or so and the component will appear.
Michael Grafton
(4,100 Views)
Thank you, this helped a ton!
(3,981 Views)
