11-01-2010 10:37 AM
Half of my menu items have disappeared from Multisim 11.0. Please take a look at the image below:
In the image I included a snippet of a design to show I indeed have a design open, etc… You might notice more than half of my menu items have disappeared!?!?!? I cannot work like this. I need to change the transformer in this design to a tapped secondary. Before I change this particular design I want to “File”|”Save as…” this design and change the file name. The “File” menu item, even though present, completely lacks all the file save sub-menu choices.
Do I need to re-install Multisim 11.0?
Steve Mays.
11-01-2010 10:44 AM
Hi Steve,
It's likely that your user configuration file was corrupted. I suggest trying the instructions here: http://digital.ni.com/public.nsf/allkb/2719D00E36A4D53A8625721300685B3F. Just keep in mind that this will set your user configuration to the default- so if you customized the toolbars/menus in any way then they will be reset.
11-01-2010 10:55 AM
That fixed it!
Steve.
