Multisim and Ultiboard
Multimeter problem
I was using NI Multisim 11.0 for making an electric circuit with a piezoelectric element as a AC source of energy (15 V). It looks like this.
When I run a simulation, it shows: Error Message From Simulation: tu1: transmission line z0 must be given. Could you help me solve this problem, since this was my first time working in this program?
Thank you.
(5,882 Views)
Can you attach your Multisim file for troubleshooting? Are using custom components created with the Component Wizard?
Fernando D.
(5,854 Views)
here, I attached my Multisim file. I was using Database Manager for creating a custom component from already created one.
Thank You once again.
Best regards
(5,844 Views)
The MAX1675 component does not have a SPICE model, that's why the simulation doesn't work. Right-click the component and select Properties, go to the Value tab, you will see that the Edit model button is disabled since this feld is empty.
I tried to find a model for this component in the vendor's website with no luck.
Fernando D.
(5,837 Views)
