Multisim and Ultiboard
取消
显示结果
搜索替代
您的意思是:
Multimeter problem
I was using NI Multisim 11.0 for making an electric circuit with a piezoelectric element as a AC source of energy (15 V). It looks like this.
When I run a simulation, it shows: Error Message From Simulation: tu1: transmission line z0 must be given. Could you help me solve this problem, since this was my first time working in this program?
Thank you.
0 项奖励
1 条消息(共 4 条)
5,894 次查看
Can you attach your Multisim file for troubleshooting? Are using custom components created with the Component Wizard?
Fernando D.
0 项奖励
2 条消息(共 4 条)
5,866 次查看
here, I attached my Multisim file. I was using Database Manager for creating a custom component from already created one.
Thank You once again.
Best regards
0 项奖励
3 条消息(共 4 条)
5,856 次查看
The MAX1675 component does not have a SPICE model, that's why the simulation doesn't work. Right-click the component and select Properties, go to the Value tab, you will see that the Edit model button is disabled since this feld is empty.
I tried to find a model for this component in the vendor's website with no luck.
Fernando D.
0 项奖励
4 条消息(共 4 条)
5,849 次查看
