Multisim and Ultiboard
Maybe a Problem with 78xx regulator
In a simululation I found an Error while using 7812 regulator. I tried to simulate a power supply with 230VAC without transformer. I need only 10mA at the output.
After the simulation I tried to build up tis circuit in real and found out, that it doesnt work properly. I got not more than 3 Volts out of it.
Then I simulated the 7812 for itself and I found an error. It delivers under all circumstances 12.xx Volts even without a power source. I tried the other ones and found out that 7805 was working properly, all the others hat te same mistake.
Am I wrong or is there a malfunction in the models?  I am usinf the students version 13.0
Regards
HorstHühn
(3,438 Views)
Yes, it looks like incorrect behavior. Thank you for pointing it out!
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(3,329 Views)
Yes, I noticed the same problem when trying to simulate a power supply.  The 7805 regulator is the only one in the 78xx family that works like the real circuit.  All others have a mysterious voltage at the input when disconnected, so the output never goes to zero.  I attached a Multisim simulation to illustrate the issue.  I added pull-down resistors on all the inputs but they made no difference.
(1,901 Views)
"После моделирования я попытался создать эту схему в реальном режиме и обнаружил, что она не работает должным образом."
Входное напряжение стабилизатора не более 35 вольт, а вы подсунули 220!
Он вообще должен сгореть, или пробиться.
(1,884 Views)
