Multisim and Ultiboard
取消
顯示結果
搜尋替代
您的意思是:
Long Tail Phase Inverter 12at7
I realize that vacuum tube amps are a lesser technical form of electronic appliance.  However, I am attempting to simulate one nonetheless.
I have been trying to simulate an amp that I have built in order to simulate different mods but every time I have encountered a Convergence Error.  I have narrowed down the error to happening only when the the tube models involved in the Long Tail Phase Inverter are connected to the circuit.  Clearly, this circuit works, as I have built it, and guitar amps have been using this type of phase inverter for over 50 years in amps like the 5F6A Bassman and the AB763 Deluxe Reverb.  Has anyone else managed to make a push/pull tube amp work with a standard Long Tail Phase Inverter in multisim?
0 積分
1 條訊息(共 8 條)
7,208 檢視
I have using a 12AU7 in my McIntosh MA230 simulator (see attached schematic).  Make sure you don't "overdrive" the NI tube models though!
0 積分
2 條訊息(共 8 條)
7,192 檢視
I don't yet have a lot of experience with Multisim's tube models but how do they compare to their real life counterparts?  My circuit is giving me convergence errors without even applying a signal voltage to the circuit- just B+ and filament voltage.
0 積分
3 條訊息(共 8 條)
7,175 檢視
Im' still working on that issue - see my posts (I'm "jmack") at http://www.diyaudio.com/forums/tubes-valves/243950-vacuum-tube-spice-models-73.html#post4211642.
0 積分
4 條訊息(共 8 條)
7,134 檢視
Since the 12AT7 was omitted from the Multisim 13 Database, I suspect that you're using one from an older version.  The 12AT7 model (and most-all of the others?) in the Multisim 10 Database are not good models (the left hand side of the Triode Plate Characteristics parabola isn't suppressed).  You can easily check them by using "DC sweep" Analysis with the plate voltage as "Source 1" and the gate voltage as "Source 2" with plate current as the output.  You can download datasheets for comparison from http://www.drtube.com/en/library/tube-datasheets (as well as amplifier schematics).  For tube ("Valve") SPICE models (and another source of datasheets and schematics) see http://www.duncanamps.com/spice.html.  Multisim 13 Power Pro uses the Dave Cigna models.
0 積分
5 條訊息(共 8 條)
7,112 檢視
0 積分
6 條訊息(共 8 條)
7,111 檢視
You kinda got me curious so I generated some Plate Characteristics Graphs for several the 12AT7 SPICE Models.  It looks like the Koren model most closely matches the data sheet.   See the attachment.
0 積分
7 條訊息(共 8 條)
7,104 檢視
Thanks for all your interest you guys. Yes I have an older version 12. It seems like whether I use 12at7 or 12ax7 they all have the convergence error. I'm not an engineer YET! Just a student and so I am not entirely amazing on the simulator yet. I'll take a look at the links you sent and see if I can get it to work
0 積分
8 條訊息(共 8 條)
7,071 檢視
