05-01-2014 12:17 PM
05-07-2014 04:47 AM
I think the best way is to copy the schematic part that you need towards your new schematic.
But you should do this first before adding other parts to the new schematic.
this way you'll be able to keep all the refdes the same.
before taking that schematic to Ultiboard, copy the desired layout and components (and vi'as, copper areas etc) to your new layout,
then import your new netlist.
I think that should work (I've done this before on small designs.)
The only thing to check are the copper area's that are linked to specific nets, they might need to be reassigned...
Good luck!
05-07-2014 05:42 AM
05-07-2014 05:57 AM
To do so, a good way would be to have that set of parts/refdes to be copied as R1A-R9A, R1B-R9B, R1C-R9C, in case a design would onlmy have 9 resistors.
so there cannot be any interference with other refdes in the existing (or base) design.
Johan
