03-02-2010 02:41 PM
I've created a design and hunted down suitable models, but when I attempt to simulate, I get the following errors:
 ------ Checking SPICE netlist for DIB_channel - Tuesday, March 02, 2010, 2:30:36 PM ------
SPICE Netlist Error in schematic RefDes 'xmm1', element 'xmm1':  Invalid subckt definition name 'xxmm1_175423184'
SPICE Netlist Error in schematic RefDes 'xmm1', element '<unknown>':  Due to errors, the subckt instance 'xmm1' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes 'd37', element 'xd37':  Invalid subckt definition name 'di_mmsz5254b__jgparts__1'
SPICE Netlist Error in schematic RefDes 'd37', element '<unknown>':  Due to errors, the subckt instance 'xd37' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes 'd101', element 'dd101':  Unable to interpret 'di_s1jb__jgparts__2'
SPICE Netlist Error in schematic RefDes 'd5', element 'dd5':  Unable to interpret 'mmbd914lt1g__jgparts__1'
======= SPICE Netlist check completed, 6 error(s), 0 warning(s) =======
Someone else has reported a similar problem (http://forums.ni.com/ni/board/message?board.id=370&message.id=7182&query.id=1608889), but their problem was due to a space in the family name. I don't have spaces in any of the names I'm using.
Help!
03-03-2010 10:24 AM
03-03-2010 11:02 AM
Thanks Yi !!!
Jeff
03-07-2012 02:37 PM
Hi!
I have de same problem as him, but... I have the '.ends ' command:
------ Checking SPICE netlist for ModeloEL34Funcionando - miércoles, 07 de marzo de 2012, 21:34:56 ------
SPICE Netlist Error in schematic RefDes 'u1', element 'xu1': Unexpected '3' found on subckt instance line - too many nodes or parameter value missing name.
SPICE Netlist Error in schematic RefDes 'u1', element '<unknown>': Due to errors, the subckt instance 'xu1' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes '', element 'x%p': Invalid subckt definition name '%m'
SPICE Netlist Error in schematic RefDes '', element '<unknown>': Due to errors, the subckt instance 'x%p' has been omitted from the simulation
======= SPICE Netlist check completed, 4 error(s), 0 warning(s) =======
I attach the circuit and the model code.
Could anyone have a look?... I'm a complete beginner and I'm having a lot of trouble with this.
Thanks for helping.
03-09-2012 08:50 AM
Hi Zung,
Your pin mapping table is incorrect. Please have a look at the component tutorial from the following link, go to step 7, it explains the subcircuit statement for a SPICE model and how you mapped to symbol.
http://zone.ni.com/devzone/cda/tut/p/id/3173
THe model you are using only have 4 pins and this inforamtion came from this statement: .SUBCKT EL34 A S G K. When you do the pin mapping in Multisim, it shoulb be like this:
03-09-2012 09:04 AM
Thank you for the explanation.
I have removed the unuseful pins, moreover it happened that I duplicated the pin information in the script. It was a complete mess.
