Multisim and Ultiboard
Identical Components in Multisim
I'm designing a circuit that has many identical non ideal capacitors (inductors) that have a specific C = f(V) [L = F(I)], but I need to change the constants after performing a simulation. Is there a way to link the components so that I only have to change 1 component instead of dozens? I'm trying to eliminate places I can make mistakes.
Thanks.
(4,957 Views)
Accepted by jp82
I'm not sure which Multisim version you are using, but starting in 13.0 you can use circuit parameters which may help you with this (View menu > Circuit parameters)
For some help getting started with them please see here or here
I hope that helps,
Jeff
(4,877 Views)
Hi Jeff,
That worked well. I can even use the parameters in the formulas for C=f(V) etc.
Thanks!
(4,871 Views)
