02-15-2011 02:10 PM
I have tried to use the Title Block Editor to make a revision history list block, but I can't get away from the structure of the title block with its forced field types, etc.
Is there a way to create a revision history block? Thanks much, Tod
Solved! Go to Solution.
02-17-2011 12:00 PM
Are you using one of the Title Block templates included in Multisim? or, did you create your own Title Block?
You should be able to edit the fields in the Title Block Editor; in the Spreadsheet View (View>>Spreadsheet) you can change Names, color, fonts, etc. Could you please elaborate your question?
02-17-2011 01:07 PM
Thanks for getting back to me Fernando. I designed my own Title Block template, not seeing one that was suitable in the list. I entered the Title Block editor and inserted 4 custom fields to be used as Rev. fields.I then tried to edit their contents by double clicking the field in the spreadsheet view. There was no response to this action. When I exited the editor (going back to schematic capture) and placed the title block I had made, it looked like a blank square. I double clicked on it and saw the typical field edit features (Title, description, revision, designed by, etc.) configured as it would be for a normal title block. I edited the 'custom fields', closed the 'editor' and I see the first Custom field's contents repeated 4 times instead of the data I entered in each field. I was hoping to construct some border lines around the fields as well, but I can't figure out how this is done either. Let me know if yo need more info. Thank You, Tod
02-22-2011 01:24 PM
Hi Tod,
Could you please post your custom titleblock? Just place the title block on a new circuit and attach it here. I'd like to do further testing.
What's your Multisim version (Help>>About Multisim)?
Fernando
02-22-2011 01:52 PM
Hi Fernando, I have attached the file you requested. Version is 10.1.1 (10.1.372). Let me know if you need anything else. Thanks, Tod
02-22-2011 03:59 PM - edited 02-22-2011 04:00 PM
Hi Tod,
Right-click your title block and select Edit Symbol/Title Block to open the Title Block Editor. Here is a screenshot for reference:
Let's start by drawing the borders. The blue circle indicates the Resize Boundary Box. Click here to change the size of the area where you want to draw the title block.
Now place the headers (green circle): click the Place Text icon on the toolbar and type REV1, etc.
Finally place the custom fields (red circle), this is the info that you can edit when you double-click the Title Block. To enter these fields select Fields>>Custom Field 1, 2, etc.
Close the Title Block Editor, double-click the Title Block and enter the information to your custom fields.
I also attached the title block that I created.
I hope this helps.
Fernando
09-28-2012 11:53 AM
He started to give me headaches multisim software! ![]()
Just a couple of days trying to find a solution to the growing number of characters allowed in the Title Block, "Design by" field (I mean #DESIGNED) and fail!
Someone help me please!
10-01-2012 12:08 PM
Can you provide us with some more details about the issue. Can you please also post the Multisim file with the title block.
10-01-2012 12:26 PM
I got it. Thank you very much Tayyab and Fernando. I tried to send a kudo a while back, but had something wrong with my cookies and it kept getting rejected. Cheers, Tod
