01-27-2018 09:36 AM
Hello, please tell me how to make 4 separate generator of square signals to one generator had a phase of 0 degrees, second 90, third is 180, fourth is 270?
01-27-2018 09:52 AM
I mean this
But this is Sin-generators, i need the same Square generators, whith separate phase-s
01-29-2018 11:51 AM
Hi ! Did you try to use this : http://zone.ni.com/reference/en-XX/help/375482B-01/multisim/functiongenerator/
01-29-2018 12:31 PM
It won't work. I need 4 (four) separate generator square waveform. But! To signal the first generator was in phase 0 degrees. The signal of the second generator phase is 90 degrees. The third signal generator and the phase was 180 degrees. The fourth signal generator 270 degrees.
01-30-2018 06:40 PM
Did you try using the Pulse Voltage source under the Signal Voltage Sources??
01-31-2018 06:10 AM
How?... can u show me pls on pic?
01-31-2018 07:09 PM
Let try to do it, I think that maybe playing with the AC analysis phase we can accomplish that.
