Multisim and Ultiboard
How to Create A Magnetic Field Generator and Sense Coil
Is there a way to create a magnetic field generator or have some sort of magnetic field in Multisim? Also, is there a coil setup that can be setup that can be used to sense the magnetic field and have a measureable voltage on the coil? It would be perferred for the coil to have a saturable core.
Thank You.
Message 1 of 10
(10,638 Views)
Hi Akhurash,
Multisim doesn't simulate magnetic but you can use voltage or current to emulate magnetic.  In the database, there is a coreless coil and magnetic core and you can use these parts to emulate you magnetic components.  These parts are located in "Basic" group under the "Basic virtual" family.
Have a look at the attached file for instructions how to use these parts.
Tien P.
Message 2 of 10
(10,612 Views)
Thank you very much for the reply. Can you provide the circuit you used for the simulation? I can't seem to get the same results as you did.
Message 3 of 10
(10,587 Views)
Hi Akhurash,
Here you go
Tien P.
Message 4 of 10
(10,566 Views)
How did you obtain the graph in the first Word file you posted? The one with the B-H field? Also, is there a way to make the graph of the B-H field flat? What I'm trying to do is create a B-H curve with a flattened (or constant) H-field after a certain amount of B-field has been applied.
Message 5 of 10
(10,564 Views)
Hi Akhurash,
Multisim doesn't plot B-H curve, I made that curve for demonstration purpose using current and voltage.
Tien P.
Message 6 of 10
(10,551 Views)
Do you have plans to put that feature in Multisim? Old version of Microsim had that feature.
Message 7 of 10
(10,482 Views)
Hi Piotrek,
I don't know if this is on the list of but I will add it to the feature request.
Tien P.
Message 8 of 10
(10,436 Views)
Thanks. I was playing around with an evaluation version of "12" .You have a nice transistor tester that you created in Labview. Maby something like that?
Message 9 of 10
(10,434 Views)
how this file is used?
Message 10 of 10
(8,737 Views)
