Multisim and Ultiboard
How do I place or create a spark gap?
The spark gap I'm trying to place is simply a Champion spark plug with the electrode ground off that's used as the preionization process for our TEA laser.
(5,054 Views)
If you are just trying to simulate the circuit, maybe using a zener diode place of the spark gap.  Set the zener voltage to what you expect the spark voltage to be.  It doesn't conduct until above the set voltage.  Just a thought.  Tweaking will probably be required.
(5,004 Views)
Or use a neon bulb and set the ignition voltage
Greetings from Germany
Henrik
LV since v3.1
(4,886 Views)
