Hi, I'm new to Multisim, and I was wondering how to create a dependant source. For example, if the voltage drop on a resistor is designated as V_x, and I wanted a dependant voltage source whose value was 2*V_x.
Yes, you can definitely do that with Multisim. Please navigate to Place->Component->Master Database->Sources->Controlled voltage sources->Voltage_controlled_voltage Sources. That component should enable you to build a dependent voltage source.
