Multisim and Ultiboard
How do I add components to Multisim 11?
Hi there.  I am trying to add a component to Multisim 11.  It is the Motorola MC3418P Continuosly Variable Slope Delta Modulator/Demodulator.  I can't seem to find anything to help me on this so ANY help is greatly appreciated.
(6,900 Views)
If you need the component for schematic purpose only, you can go through the Component Wizard to create you own symbol, this option is under menu Tools>>Component Wizard. If you need this component for simulation, you need a SPICE model, I did a quick search and unfortunately, I was not able to find one.
Tien P.
(6,870 Views)
Hello! Where can i find SPICE files for 2sc2073, 2sc5200, 2sa940, 2sa1943, 2sc9014, 2sc3200 transistors?
(6,841 Views)
Most SPICE models are created by the component manufacture so you should check their website.
Tien P.
(6,809 Views)
Unfortunately, I do need it for simulation.  I guess I'll keep searching around.  Thanks!
(6,794 Views)
