Multisim and Ultiboard
How can I design a single layer board in Ultiboard?
The students I work with design some very simple boards and we want to make them single layer, mainly because we etch them ourselves.  Is it possible to set-up Ultiboard to route on a single layer?
(3,949 Views)
Accepted by Wes_Plybon
Ultiboard always has at least two layers, but you can turn off routing for individual layers. You will then get DRC errors for any copper on the "off" layers.
  1. Open the design
  2. Click Options > PCB Properties and select the Copper layers tab
  3. In the Allow routing box, change the layer name Copper Bottom, and click Properties
  4. In the Copper Layers Properties dialog, uncheck Routing. It should look like the image below
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,943 Views)
