Multisim and Ultiboard
How can I copy and paste an on-sheet connector without the name changing?
Any way to do this?
If not it would be a very nice feature to add.
(8,521 Views)
Accepted by dbur
dbur,
Thanks for giving us an easy one this time...  🙂   The feature does exist (although its not default).   Copy the On-Page Connector (Ctrl+C) and instead of a straight paste (Cntrl+V), you can do a (Cntrl+Shift+V) - or go to Edit -> Paste Special -> Paste without Renaming On-Page Connectors to accomplish the same thing.   This will duplicate the On-Page Connector and also copy the net information as well.
I've advised R&D that if users are copying an existing On-Page that the default behavior should be changed to allow the same Connector/Net copy to be placed in multiple locations (without renaming it to a new On-Page Connector).  If you also think this should be the default case, let us know!   R&D was 'playing it safe' to eliminate the chance that a duplicate connection would be made unintensionally.
- Pat
(8,516 Views)
Yes, keep them the same by default!   That's the way it works now for global sheet connectors, though I would think they are more dangerous.
Thanks for the tip.  I tried various things like holding cntrl down but didn't stumble on the right one.  Sometimes I want to clone 10-20 at a time and this will make it much easier.
(8,510 Views)
dbur,
Yes global connectors, when copied, preserve the name and attached net.
For local on-page connectors the current default is to create a unique label and not preserve the net information.  I will pass your feedback along to R&D as I agree that the use case you described (of copying 10-20 and sprinkling them around the schematic to create common connections) is the one I was thinking would be the most common for a copy/paste action.   If you are creating a new on-page connector from the menu, then the behavior should be to give a unique name.
Appreciate the feedback.
Pat  N
(8,504 Views)
I agree, that should be the case.
(7,795 Views)
